Question about Sony LMP-H150 Projector Lamp Projector Lamp for VPLHS3
Lamp replaced, and warning to replace lamp message still shows
Sony projector, running through DVD / VHS player Lamp replaced (correct lamp type), and the instruction in the manual states that the user should press the "reset" left arrow, right arrow, and "enter" buttons for less than 5 seconds for each. This has been done correctly, but the warning message to replace the lamp still comes up when the projector is turned on. Pressing any button on the remote control will make the warning message go away, but it returns the next time the projector is turned on. Also, there is a bright blue tinge to the right hand portion of the image projected, which appeared prior to the lamp being replaced. This blue tinge remains even when I change the type of screen type to the likes of dynamic, or cinema, but if I change it to a shorter screen, the blue tinge stays in the same place and in the background.
  • pmandel Sep 12, 2008
    Sony VPL-ES3 and the replace lamp message won't go away
SOURCE: purple scribbly lines it left hand corner of tv screen
I don't think it's your bulb - sounds/looks like the known "roadmap" problem, they say they will cover it. Check this out: http://esupport.sony.com/perl/news-item.pl?news_id=127&mdl=KF50WE610 Now if they'd just cover the known "blue blob" problem I'm having...
Posted on Dec 26, 2006
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
SOURCE: KF 42WE610 turns on for two seconds, then goes black
no, had the same problem. Its the lamp ballast also called the lamp power block. It supplies power to the lamp, any how some repair shop wanted $450 to fix it, so i ordered the part from sony, part #146879816 ($116.25), trust me this is the part I double checked with many different places. Any how fixed it my self took about 15 minutes, just take the back cover off and the part is right there just kind of follow the screws and the 3 wires, super easy job, I suggest you replace the bulb at the same time, dont by a cheap bulb just get it from sony
Posted on Jan 23, 2008
eagle338
  • 4889 Answers
SOURCE: Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Posted on Feb 23, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony VPL-ES3
What documents you need for VPL-ES3, let me know please.
Have you replaced Lamp? give details of projector problem to find out solutons.
Posted on Sep 12, 2008
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    Warning message for lamp replacement appears at each power up!
    After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
    Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
    My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
    First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
    resetting procedure.
    1. inset the new lamp.
    2. power on the projector.
    3. Press menu and select OPTION.
    4. Press enter button and the select LAMP RUN TIME.
    5. Press and hold MENU button for 3 seconds.
    6. Lamp reset , power off message will display.
    7. power off the projector. this will reset the lamp hour.
    Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
    ok
    Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
    After two hours we are getting the High Temperature Warning. This is getting worse as time goes on.
    Check the lamp cooling fan of your television . maybe its have some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp warning displays.Do one thing, Remove the fan from the television. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch. if get the same fault then try to replace the lamp cooling fan.
    ok
    Mar 10, 2011 | Sony KDS-R50XBR1 50" HDTV
    How do you install new light bulb
    The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
    When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
    1. Switch off the power to the projector by pressing the Power/Standby button.
    2. Allow the projector to cool down at least 30 minutes.
    3. Disconnect the power cord.
    4. Use the screwdriver to remove the screw from the cover. (1)
    5. Push up and remove the cover. (2)
    6. Remove the 2 screws from the lamp module. (3)
    7. Pull out the lamp module. (4)
    To Replace the lamp module, reverse the previous steps,
    Feb 28, 2011 | Optoma EP716 Multimedia Projector
    I have two Panasonic PT-LB10VU projectors doing the same thing. They project find with RGB, but when trying to project a VHS tape through video, the image rolls or has multiple lines running through it. ...
    first of all you replace the present video driver VHS tape and try any other dvd driver or any other video device if problem exist then the main board of you projector is faulty.
    Solution: open the upper over remove 5 screw back side of projector.
    disconnect the panel ribbon cable.Remove lamp cover with 3 screw remove main board with 4 screw and 8 connector. put it face down on a table and use a table lamp for more light.
    check very carefully the area I show in the picture with red arrow there is a resistor no.R041(on resistor 750) is burn out or black replace witch 75ohm resistor and check around the resistor if burn any other component replace with the same after repair of main board fix the all part of projector as you open. Power on and use any video device other than your VHS tape maybe the high voltage comes on video output.
    Dec 20, 2010 | Panasonic PT-LB10VU Multimedia Projector
    Reset option killed the yellow warning to replace the bulb, but didn't reset timer...it's still showing 4,400. I bought new replacement lamp from www.electried.com, but it's showing dark. Is it the lamp or...
    The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
    Feb 09, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
    Sony VPL-ES3
    Sep 12, 2008 | Sony LMP-H150 Projector Lamp Projector...
    Removing the "lamp needs replacing" warning message
    Hi guys
    Firstly you need the remote to reset the lamp timer.
    Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
    Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
    Sony LMP-H150 Projector Lamp Projector Lamp for VPLHS3 Logo
    124 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
