Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Power cord for Dell Monitor 2005FPW
I have two similar powercords and am not sure which one is for my Dell Monitor. Both seem to fit. 16AWGX3C 105 degrees C ll81924 is the first cord. The other one is 18AWGX3C 75degrees C LL81924.
    Novelist:
  • 180 Answers
I got this from the website at Dell. It looks like the cord you want is the second one. I'm basing this on the fact that normal operating wattage is 55w with a max of 74w and that would describe your second cord. The first one wold provide too much power.
VESA Modes
Horizontal Sync
Vertical Sync
Video
Power Indicator
Power Consumption
Normal operation Active Active Active Green 74 W (maximum)*
55 W (normal)** Active-off mode Inactive Inactive Blanked Amber Less than 3 W Switch off - - - Off Less than 1 W(at 110 Va)
Posted on Feb 14, 2009
Where can I get a power cord for a Dell Ultrasharp Monitor # Mx-09j367-47605-31l-a5m7
The computer repair store nearest you or tv shop should be able to provide you with the power cord. They are standard in the industry.
Dec 30, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW shut down wont power up.
You can have the board repaired for $50 or you can inspect it first for bad connectionc, bad caps, etc.
http://www.lcdrepair.us/2005fpw-power.html
Apr 22, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
How and where i can find aschematic for dell 2005fpw.
You can start from here if this helps.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
Dec 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Opening Up a Dell 2005FPW
Hi...there,
If you got power with no screen or both... Then it's your backlight inverter are busted. Need to replaced or repaired. To repaired look for a capacitors with a bulged on top of each caps. Not sure...just replaced all the caps... Good lucks!
Oct 07, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
141 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
