I have also tried to use this mic on my Mac, It works, but there is a downfall with this mic on a mac, or at least my mac-mini and osx 10.6 (fully updated). Here is the problem, to use the prosound usb mic in an audio recording program you have to change the audio settings on the mac to record sound from prosound mic, if you do this you can no longer make use of the built in core stereo, this then disables any other sound I am importing into my project. I tried to set up a composite device where I should theoretically be able to record from the usb mic and the stereo core audio simultaneously. Tried it and still doesnt work. To be honest I am better off using my SE2200A 48v Phantom Powered mic via the BOSS BR1600 Recording console, which works fine on both mac and xp! To ProSound I think that as Windows XP does not always have the drivers to power your product even if it does recognise it, then you should include a driver disk for this product as standard.
SOURCE: Samson G-Track recording volume issue
ok thats good, when you go to device manager do you see the USB Microphone listed with no conflicts such as ?, X, !..?
SOURCE: troubleshoot
The mic is on the left side. That's how it's supposed to work. You should set your recording software to only record the left channel on one track and the right channel on another track.
The level controls are the knobs on the front.
SOURCE: static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
have you tried removing all that are connected to the USB ports or try other USB port
Yes I have, But thanks for the input
