Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Fixed power cord, clock works, doesn't heat
Recently when I moved the range to clean, I heard a "pop" when I moved it back. One of the power cord strands had slipped off the block and caused a small burn mark. I replaced the block, re-connected the cords, checked the circuit breakers. The clock works, but the stove and range top don't heat. I looked for a fuse but couldn't find any. I wonder if the short fried my circuit board. Got any ideas?? Thanks.
  • 25 Answers
Sounds like only 120 volts.get multi-meter and make sure there is 240 volts at block.if not,recheck wires and check breaker.clock will run on 120 volts but elements won't.
Posted on Feb 12, 2009
    President:
  • 878 Answers
SkyKing, are you handy with a meter? sounds like you are losing a leg of power here. Check for voltage at the terminal block (where the cord hooks up. You should read, 120V from left to center, 120V from right to center and 240V across the two outer terminals. Check this first and post back. Catriver.
Posted on Apr 20, 2007
Range not working
Maybe one wire is off.Check that ting it is OK.
Mar 14, 2013 | Kenmore Kitchen Ranges
Clock assembly light fading. Did self cleaning oven and it fixed it. Do I still need a new assembly?
The self cleaning heats the oven to a temperature higher than standard operating temp for the panels to burn the dirt off, this also heats up the rest of the oven, Your clock module will have dry solder joints, these can be fixed and if you are handy with a soldering iron it is a reasonably simple job. Just be sure to disconnect the power before removing the clock module.
Mar 10, 2012 | Magic Chef 31203 Gas Kitchen Range
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Sep 08, 2007 | Kitchen Ranges
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
152 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
