My lexmark will install teh printer but not the imaging studion. new Pc using windows 7 old Pc under windiows XP worked fine. installing software off of CD. It does not seem to do the install completely but sais it is happy.
Teifion Thomas:
If you did the complete install of the software, then the program is there, you just don't have a shortcut icon on your desktop. You'll have to click on "start" then find the folder that contains your imaging studio software executable file (when you double click on that icon, imaging studio comes up on the screen). resize the window so that you can see part of your desktop behind the current window, left click on the executable file icon and drag it to the desktop and release the mouse button. Click on create shortcut and you'll have an icon for your imaging studio on your desktop.
It has not copied half the files from the CD. I have checked the icon it created and it keeps complaining of missing exevutables like lxcrlpx and when i manually copied it to the correct area then it complained of missing lxcrgf.dll (however I have no clue where this shoudl be placed) so overall the installation does not seem to be working,
Downloaded driver as per Thomas F Schneider recomendations this fixed the problem thanks
SOURCE: PROBLEM WHILE INSTALLING MY LEXMARK X1110 PRINTER IN WINDOWS VIST
Go to the Lexmark website and download driver for Vista.
SOURCE: how to install my lexmark x1100 all in one printer without cd
First thing you need to do is uninstall the current software and printer.
Then go to: X1100 Series Driver
Select your operating system...Vista...from the drop down menu.
The next page has the link to download the driver. (It should be cjrX1100EN.exe. Click on "Download Now".
When you begin the download and the download window appears, select "Save" and direct the download to save to your desktop.
After the download is complete, close all the windows, or other programs.
Make sure your printer is ON but also that the USB cable is DISCONNECTED. Double-click the file on your desktop that you downloaded. When prompted by the software, connect your USB cable.
That should do it. If you run into any problems, just comment back.
Thanks for using Fixya.
SOURCE: Lexmark Imaging Studio
Hi. It would really help a lot if you also have the installation cd for the printer. The scan software can be installed using the cd. I believe it's not available for download on the internet since it's a big file. Hope this helps.
SOURCE: INeed Lexmark Z65 Windows 7 Driver
MOST Lexmark printers are not compatible with Windows 7 .
Go to Lexmark.com and you can verify if they have your driver
Click onto the tab that displays DRIVERS
Using the printer control panel
1. Open the top cover, and then load an original document face
down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned
image.
3. Make sure that the printer is connected to a computer,
and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
1.
Open the top cover, and then load an original document face down on the scanner
glass.
2.
Close the top cover to avoid dark edges on the scanned image.
3.
Do one of the following:
In Windows Vista, click > All Programs, and then select the printer program
folder from the list.
In Windows XP, click Start > Programs or All Programs, and then select the
printer program folder from the list.
4.
Click Lexmark Productivity Studio.
5.
On the main screen, click Scan.
6.
Follow the instructions on the screen.
Using Macintosh
1.
glass.
2.
3.
From the Finder desktop, double-click the printer folder.
4.
Double-click the 2600 Series Center.
5.
From the "What is being scanned?" list, choose the type of document to be
scanned.
6.
Click Scan.
