Question about Magellan Roadmate 760 GPS Receiver
Bot up problems
I have the problem that when I turn the unit on it boots to the user screen then re-boots from 4 to 10 times then the unit will finaly let me select a user. I have no problem having it serviced but I'm afraid that it needs a hard drive. if I need a hd what do I need and where do I get the software to install on the hd.
    Novelist:
    Scholar:
  • 86 Answers
Definitely a software problem. Try resetting User Data. Once your able to select a user, don't. press the - key (zoom out) and the repeat button (on top), select reset user data, your information and points of interest will be cleared upon doing this fyi. If this does not fixya, then more then likely yes it is your hard drive. If you have the software DVD/CD, then try re-installing the current version of software. If you don't, then sending it to the Magellan repair shop in Fort Worth, TX will be your next move. I'm not aware of any place you can purchase just the hard drive and the program/devices used to program the hard drives is proprietary.
Posted on May 03, 2007
My 749 Emerson tablet has a pattern lock and I forgot it, my user name and password, what do I do?
You will need to Factory Reset the tablet. Warning: You will loose everything on the tablet and it will be wiped out completely, returning it to the day you took it out of the box.
1. Turn unit off
2. Hold VOL+ and the Power button at the same time for a full 5 seconds then release both. A dead Android bot should show.
3. When the bot shows, again, hold the Power and VOL+ together, then release VOL+ first, then the Power button last.
From here, you should see "Android System Recovery" on the screen.
4. Used the VOL+ and VOL- to scroll through the selections to pick "wipe data/factory reset" and press the Power button.
5. Use the VOL buttons to move to "Yes - delete all user data" and hit Power to select.
6. Use the VOL buttons to select Reboot now and hit Power.
Once complete it's as if you opened the unit for the first time out of the box.
Mar 18, 2016 | Tablets & eReaders
Need bissell spot bot oners manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 04, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
We have a spot bot we inheritied without a users
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Jul 30, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
I went into yahoo messenger country music chatroom 34 and i got like 60 im's and it froze my screen and now my password doesnt work and its locked and wont let me back in
That is called bot....you were boted when you were in chat room...advance user uses this system to kick out the user from chat room..this type of software known as anti-yahoo software....nothing to worry ...just sign in on your yahoo messenger click on Messenger>Preferences or Ctrl+Shift+P Now click on Ignore List, from here select Ignore anyone who is not in my yahoo contacts or Alt+I, it will block any incoming unknown bot. To save yourself from bot and net DC/Sign out ... use yahoo chat client like Yahelite , Yazak , Ysupra etc. ... To unlock your ID go here... http://www.yahoo.com/r/m6 or http://mail.yahoo.com first time put your ID and password & press sign in...the login page will appear again ....put ID, password & Captcha word correctly this time.... your ID will be unlocked now....hope my suggestion helps you..have a good day
Oct 27, 2009 | Yahoo Messenger
Boot Disks Required
Open my computer select A the floppy drive and do a right click and select boot disk
and enter
bye
Mar 24, 2009 | Computers & Internet
System will not Boot
when the system bots up press del & go to bios settings, look for a section where is says boot sequence or boot device. select the had disk from the drop down menu.
Mar 21, 2009 | E-Machines eMachines Desktop PC
Sony Vaio laptop vgn-fs640-w problems
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Jan 18, 2009 | Computers & Internet
GPS wont boot up
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Sep 28, 2007 | Garmin GPSMAP 276C GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
