Question about Brother MFC-5840CN All-In-One InkJet Printer
Printer prints backwards/upsidedown
Hello, I have a printer that has suddenly decided to print backwards/upsidedown. It only does this with pdf docs and printing off the internet. Seems to print fine from excel and word programs. Instead of printing from left to right, it prints right to left and you would have to put in from of a mirror to read. Have not been able to identify the cause or how to remedy. It is very odd! Can you help?? In Gratitude, Joetta Marie
  • ozipper613
    ozipper613 Jan 23, 2009
    I have a similar problem. My printer was working fairly well, but last week or slightly before began printing mirror-image and backwards, out of the blue!
    I checked the printer 'properties' and the option mirror image was not checked in error, so I don't understand why this problem is occuring.
    Scholar:
  • 135 Answers
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Posted on Apr 18, 2007
In Gratitude,
Joetta Marie
Posted on Sep 17, 2008
This is a fairly new problem existing today
The Intelligence agency's all know about this
This started recently with Credit Reporting Agencies
And I don't think it's very funny!
The problem is NOT with our Print controls
This is being caused by the online companies we are attempting to download our financial or credit information from!
Ted
Posted on Mar 23, 2010
SOURCE:
Every time I go to print a single 1 page pdf, my printer prints backwards. How can I get it to stop printing images in reverse?
Open up the printer preferences from "Devices and Printers" and click to print in default settings, then apply and OK
Same in PDF Viewer
Dec 01, 2015 | HP OFFICEJET PRO 8630 eAiO
Why Why is my hp photosmart C5580 All In One printer printing words backwards
May i know which application are you using to print from ?
I guess "Mirror printing" is enabled , hence you are getting its desired effect.
Open a Notepad and print, let me know if issue still persists.
Aug 22, 2012 | HEWLETT-PACKARD Photosmart C5580...
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
Jun 01, 2010 | HP PSC 2210 All-In-One InkJet Printer
Suddenly won't print PDF files
open pdf file
then click on print
then in advanced or in any other tab look for option print as image
make sure that the box is checked
Mar 01, 2010 | HP LaserJet 1300 Printer
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP L7780 All-In-One printer. Reverse printing.
Please check the printer setting in your driver and application. The the printer just does what it is told to do by the software.
Nov 10, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Toner is not out of ink but it lights up, refusing to print
In most cases cartridges have a special chip that remembers the toner cartridge serial number an amount of pages printed from it. This means, that even though there still might be some toner left in the cartridge, the chip's counter reaches it's predefined limit and informs printer, that the toner has run out. Just like that, suddenly.
It may also be the case, that the chip loses contact with the printer's electrical terminals - try reseating the cartridge in the printer. If that doesn't help, it's time to replace it I'm afraid.
Usually the printer will inform "toner low" for some time before it becomes "toner out" and refuses to print. If you get "toner low", then it's time to purchase a new cartridge to have it ready.
Oct 27, 2009 | Fujitsu Office Equipment & Supplies
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
MY HP PRINTER IS PRINTING EVERYTHING BACKWARDS
My HP Officejet Pro L7580 is all of a sudden printing everything backwards?
Sep 03, 2008 | Office Equipment & Supplies
Brother MFC-5840CN All-In-One InkJet Printer Logo
5,716 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
