Cd roms wont read it says i/o device error - Computers & Internet
  • drocha Jan 06, 2009
    I have a toshiba satelite PN# PSP10U-0DUJPV and it is a CD/DVD RW ... but now when I enter a CD to view pictures it gives me an I/O device error. When I look at my removable disk it says DVD-RAM, when it used to say CD/DVD RW ? it has been a while since I used it, and not sure what to do?
    Scholar:
  • 57 Answers
Your error is usually indicates that the drive can't read the CD. I ask everyone these two: check to make sure the CD is right-side up (label facing up or to the right on a vertical oriented drive) and did you insert a DVD into a CD drive? Can you use Windows Explorer and right-click on the CD drive letter and select eject and it works? If not, a driver could be missing. Lastly, if you inserted a blank CD (that can be written to) into a CD drive that can only read CD's, you'll get that error.
Posted on Dec 26, 2008
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Jun 03, 2011 | Computers & Internet
My cd rom is unable to read cds and there is error in cd-rom driver....
If the Cd rom driver has an error, you can check and know if it has an error. Click on start, Control Panel, System, for windows xp, click on Hardware and then device manager, try and look to identify if your cd rom driver has a question mark on it or a yellow mark, if so, this means that the driver is corrupted, you need to uninstall it, right click on it and choose uninstall, after restart your computer.
for windows 7 and vista click on start, control panel, system and device manager, do the rest as explained earlier.
Jan 07, 2011 | Computers & Internet
Cd/dvd rom will not play or burn
you need a cd\dvd rw to be able to burn as for wont play\read
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no 4 for australia
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
I have a HT-DT-ST- RW/DVD GCC 4480B it will burn cd-r but it wont even read dvd-r I just want to burn dvd-r but it wont even read blank one
> CD-RW / DVD-ROM
Sorry, but this device is not a DVD-writer.
This device _should_ read (non-blank) DVD media.
If it does not, then the cheapest solution is to spend $40
to buy a new CD/DVD reader/writer.
Oct 26, 2010 | LG GCC 4480B CD-RW/DVD-ROM Burner
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
DVD CD ROM
yellow triangle means conflict error try updating the driver or you may have to reinstall the device
Apr 03, 2009 | NEC CDR-84 (CDR-84-1) CD-ROM Drive
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
DVD works but not regular CD ROM
try frimware update for it from site ok pioneer.com ok
Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Error Message on CD Rom - will not operate
Your CD ROM needs to be cleaned from inside may be it can't read CD because of dust on lens
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
