Question about Kenmore 15.5 in. Pedestal
Replacement kenmore pedestal front drawer cover?
I have new kenmore elite washer/drier pedestals that got scratched on the front drawer cover. Can you buy replacement front pannels? It looks like the front cover is only held on by 3 screws.
  • 61 Answers
The pedestal should have it's own model number on it. Find the model number and contact Kenmore parts depot and they should be able to get you a front panel.
Posted on Dec 26, 2008
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Can you remove the front panel on an HE washer that is mounted on a pedestal without removing the pedestal?
Hey gearman, In a word, Yes. I find it easier to extend the drawer out ( if applicable...some pedestal's don't have drawer's ) and then the panel will drop down un-obstructed once the screws are removed. Hope this was helpful and answered your question. Please take a second to rate this solution if to your satisfactory, if not let me know how I can assist you further. Thanks for visiting "fixya" and good luck. Macmarkus :)
Apr 01, 2010 | Kenmore 44932 Front Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
How do we install the pedestal to the front load Kenmore washer
The pedestals bolt into the bottom of the washer where the legs where.
This is definatly a heavy job, so it's best to get 2 more people to help you out.
#1 Remove all 4 legs that came on the washer factory.
#2 Make sure you have enough room to manouver the machines. The washer is going to be the most difficult so start with it.
#3 Have your friends tilt the machine back and you slide the pedestal under the machine.
#4 Kneel down infront of the machine to prevent it from sliding forward.
#5 Have your friends lift up the back of the machine and walk it forward until the holes in the top of the pedestal are in line wiht the holes from where the legs where.
#6 Thread in the bolts and tighten.
**You will need to take out the drawer of the pedestal to get the back bolts in. There are plastic clips on the inside of the runners, just push those down at hte same time and pull the drawer**
Good luck! Please let me know if this was helpful!
Oct 03, 2009 | Kenmore 15.5 in. Pedestal
Whirlpool pedestal w/ Kenmore Elite HE3 washer
no - the base is a different size.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore 15.5 in. Pedestal
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Jun 10, 2008 | Kenmore 15.5 in. Pedestal
Washing Machines Logo
211 people viewed this question
Sal De
fordexpert
Robert Rankin
