Question about Nintendo Super NES Console
Moving objects on screen don't display correctly
I've had the system since 1991 and i'm the original owner. i tend to hook it up 4-5 times a year to play. i recently tried to hook it up an i am now having display problems. it seems where ever there is a moving object on the screen that object is blurry. it does it with characters and moving text. the stationary backgrounds are usually fine. the audio is always clear. i've tried probably 10 different games and they all seem to have the same problem. i've also tried it on different tv sets (plasma, lcd, and the old tube display) and the characters are still messed up.
so to all the experts out there do you think it is more the system acting up, and if so what should be done, or do you think everything just needs a good cleaning?
I had the same problem. The characters had been blurry and everything was just... weird... solved it like.. 5 minutes ago.
you'll need 4 things: tweezers, a needle, small brush (really really small) and a strong light.
now.. this should work... open the "gates" for the disk, and... I don't know.. do something so that they stay open.. hhh... and.. turn on the light ( I used a small lamp)... and take a needle... you should see that under those connections there is quite a lot of space... for the dust... you wouldn't believe how much dust is in there... so, just get the dust out of there... and after you got it out (you should now see that the plastic underneath is actually black) just use a small brush for the "after touch"...
ow... and try to play around with the small black button on the back of the nintendo... try to change a channel...
well.. this worked out for me, I hope it does for you too...
good luck!
and.. sorry, my English is still pretty bad...
anyways, bye bye
/Maya
Posted on Feb 13, 2009
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
Motor runs but belts not moving, How do I fix this?
First, give it a good cleaning and oiling. It may need some grease on the gears. If the belt is still not moving, it could be too loose...stretched out. In that case you would need to replace it. This seems pretty complicated. If the cleaning and oiling don't work, take it in for service. You can download your manual here:http://www.imarksweb.net/book/kenmore+158+14100+manual/
Jul 06, 2012 | Sewing Machines
Unlock honda 98 accord radio
The dealer can get you the code with proof of ownership, provided it is an original equipment system. SOME CHARGE FOR THIS SERVICE. Check the owner's manual, as some owners (assuming you're not the original) write the code there. Otherwise there are several code lists online, just google your make, model, and year, and get a list. This is trial and error, and can be time consuming, but I,ve had some luck there, when all else has failed. Good luck!
Feb 10, 2012 | 1998 Honda Accord
Radio won't work
When you disconnect your battery or remove the fuse and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacrurers service centre andget them to enter this code for you.
Jan 30, 2012 | 1987 Chevrolet S-10 Pickup
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
HOW DO I CORRECT THE TIME ON THE DISPLAY
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 02, 2010 | Panasonic KX-T7630 Corded Phone
"C" in display window and "power failure" keeps getting announced
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
Feb 26, 2008 | AT&T 1738 Digital Answering Machine
Nintendo Super NES Console Logo
145 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
