Question about HP OfficeJet 6210 All-In-One InkJet Printer
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This line also appears whenever I fax something (Of course I have to feed the paper in the paper tray on top) I am trying to figure out what this is and how to stop it, Thanks
I have a f380 printer scanner copier, it has a paper jam inside and I cannot clear it. Any suggestions??
Posted on Dec 27, 2008
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Posted on Dec 26, 2008
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp 6210 prints a black line down the center of the page. 1st 50 copies okay, then line started.
First diagnose if the line comes when using the doc feeder or the glass. If it only comes when using the doc feeder then you have a small dirt spot on the glass where the page is scanning over the exposure lamp. Just clean it.
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Black lines on scans & copies
Please perform Solution two: Clean the ADF rollers and separator pad, provided in the follwing HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00228023&cc=uk&lc=en&dlc=en&product=421991
:) Dr Tony
May 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lines on paper through the ADF when making copies
there is a dirt on the ADF (CIS contact image sensor) that reads your document, identify where the lines came from either from top or bottom then open your adf and clean the affected area. this will solve the problem.
Jul 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
AutoFeeder Copy with Lines
TRY FOLLOWING THIS LINK http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
Oct 03, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
114 people viewed this question
Ben Johnson
