Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Agitated with my agitator and spin cycle
I have a Kenmore Laundry Center Stackable washer/dryer unit model#417.99872990. I just replaced the motor for the wash unit. The water fills and drains but when it should agitate or spin the motor just hums and puts out the egg smell. I tested and the pump is getting power, the motor is getting power, there is continuity and power going thru the capacitor, when i spin the transmission pulley it turns, the lid switch is operational, and the belt is plenty tight. I am very handy but out of ideas. Help please!!!!!
  • 2 more comments
  • Anonymous Mar 13, 2014
    wtw5700sw agitate won't spin or drain but motor hums
  • Anonymous Mar 16, 2014
    motor will not come on to spin or agitate
  • Anonymous Mar 18, 2014
    washer spins but wont agitate
    washer spins but wont agitate motor justhums
  • 5,911 Answers
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
When I put a light load into washer, follow directions, the washer starts by running water but does not go into next cycle
I would check the lid switch. If switch is faulty, it will allow unit to fill like normal, but won't agitate or spin.
Nov 15, 2015 | Kenmore 24 in. Gas Laundry Center with...
I have a stackable washer and dryer from Frigidaire model# FEX831CSO. The washer will not agitate or spin but will drain. What might be the problem?
Good Afternoon Sarah, thanks for your post!
From the information you have provided the washer on your Frigidaire laundry center will not agitate or spin and will drain. This sounds like a possible issue with your motor or belt. In order to pinpoint the issue with your washer you may need to disassemble the washer and test each component for electrical issues and cosmetic damage. This is not a simple DIY job and I would recommend you speak with a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Apr 20, 2015 | Frigidaire Washing Machines
My washer will not agitate model #wsm2700hbwww
Hi Christalee - Were you able to fix the issue. I have the same model and have the same problem...it wont agitate. Any inputs/suggestions would be great,,,,,
Jul 30, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
May 09, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
309 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
