Samsung Tantus HLN467W High pitch noise from dlp?
Over time, this high pitch noise would sound until the set warmed up, but now it is constant. It is not the fan, because the set only emits the sound when the lamp is lit, and the lamp seems to be source of the noise, if not the cause. Could this be the lamp itself or some other component? The audio also takes a long time to come on, but this seems to be a separate, unrelated issue.
  • 185 Answers
Noisycoil- idetify the coil and remove it.coat it with laquer suitable for motor winding, reinstall after dry.
Posted on Dec 26, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Philips HTS3450 - high pitched humming noise until warmed up
Jeremy,
Read one of my posts:
I used a hairdryer and blew hot air into the grill on the bottom of the subwoofer enclosure which reduced the delay time from ~1hr to 5 minutes. (The high pitched noise was still there for about 1-2 minutes)
Oct 16, 2009 | Philips HTS3450 System
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
High pitched noise coming from set.
hi there high pitched noise form the set indicates that one of the coils inside the set are lose this happens with age and heat the coils are made of copper and are tightly glued or soldered together and can be as small as a bit of hair of as big as a pen tip the problem is that the coil is now vibrating which is causing the high pitch sound and sound be quite easy to identify with a good ear!
sometimes these can be sorted with a quick bit of solder to hold it in place on the main bord of where the coil is, but some times there is no cure due to very small braiding of the copper wire any attempt to solder may cause damage and breakage,
You may be able to replace the coil with another one from a good components store with the same value best thing is to take out the noisy coil and take it down to be replaced
the reason it appears worse when first turn one is that the coil is cold and vibrates alot more just like when the set is warm the coil expands like most metals do which stops it vibrating so much
i hope this helps a little good luck
Feb 05, 2009 | GE Televison & Video
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
474 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
