Question about Linksys Wireless-G Broadband Router
Can not get the second laptop on the internet with the wireless
We have a linksys wireless-g access point router. My son has had a laptop for awhile with no problem getting on the internet. My daughter received a laptop for christmas ... we can not get her on the internet. When we try and load the linksys.. when we are looking for a wireless connection.. all the linksys are 'secured' and need passwords... our network is not a secure network.. ?? can this router only allow one ???
  • Anonymous Dec 26, 2008
    Same thing, says network is unsecured on base computer, other laptop works fine, new Mac finds the network, but tells us we need a password.
  • JDTec
    JDTec May 11, 2010
    A WAP (wireless access point) only brocast 1 IP address. You would need a router in order to use several computers on your network.
  • 258 Answers
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Posted on Jan 26, 2009
I am through which port do i connect the router linksys E900 to my laptop?
It's a wireless router, so you may not need to use a port at all.
You can connect to any of the ports numbered 1 through 4. The yellow Internet port should connect to your outside network. (Cable modem or router or Ethernet port from your Internet service provider.)
Mar 16, 2015 | Linksys E900 Wireless N300 Router
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
I can not access the linksys access point, the does not link.
the default address is if you still can't access you can factory default by pressing and holding the reset button on the back for about 10 seconds. after it restarts the ip address will be leave the username blank and the password will be admin.
Apr 15, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My laptop says connected to Linsys router but no internet connection, yet the desktop is connecting to internet
saya ada dua access point, yang digedung A saya memakai access point linksys WAP4400N dan di gedung B saya memakai access point linksys WAP54G. sekarang sudah tehubung masing2 access point, permasalahannya sekarang adalah kalau memakai laptop tidak bisa connect secara automatis, tp kalau secara manual atau memakai IP Address baru bisa connect, tolong gimana solusinya....
Nov 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Access point router and wireless router communication
You said that the router connected to the modem is acting like an access point. that means the DHCP server on that router must be disabled. The second router is connected to the first with the ethernet port. What you can do, you can enable the DHCP server on the first router and make the second router work as an access point.
so that both the computers will be in the same IP address range.
If they are already in the same IP address range then you can try to ping the second computer's IP address form the first computer.
Click here for more info.
Sep 18, 2009 | Belkin (F5D8231-4) Wireless Router...
My Linksys Wireless A P only allows one computer to connect
You need to get a router in order to share the Internet connection. The existing Internet connection (from the DSL/cable modem for instance) goes into the WAN port of the router/firewall, then you connect the AP to one of the LAN ports.
Today it is often a better idea to buy a wireless router instead, i.e a router with built-in wireless AP. They are very inexpensive.
May 28, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Problem connecting linksys wusb54g wireless to internet.
Sounds like you need to reboot the router and probably the cable modem. Unplug both, wait 30 seconds, then plug them back in. It can't hurt anything and it solves this problem 90% of the time.
Dec 06, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Linksys wrt54gs Set up
1. Unplug your cable/dsl modem.
2. Unplug your Router
3. Plug in your modem ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
5. Go to your 1st PC and get into Command Prompt. Type is ipconfig /release .... then type ipconfig /renew
6. Check for internet connectivity.
Repeat step 5 for for your second PC.
If your second PC is wireless go into the wireless config utility and search for access points. Connect to your Access point and check for connectivity.
If you still have no internet. Press the reset button on the back of the router for 45 seconds while it is powered on. Repeat steps 5 and 6.
Be sure to lock down your wireless SSID so neighbors and people passing by are unable to connect to your access point and do bad things on your network.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Linksey wireless-g usb adapter and router
lose internet connection from my second computer that is linked to main computer (main computer has internet connection). Tried to click repair and it said couldn't be repaired contact internet provider?
Nov 01, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G Broadband Router Logo
180 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
