Question about Little Tikes My Real Digital Camera
Found the problem, with camera
Figured out what the problem is .you know the little door.when you plug it in the wire stops from going all the way in cause the little door preventes it to go in even if it says usb on the cameras screen it dosent mean that it's plug in right so i took a sharp object and held the little ddor wide open for the usb cable to plug in right and after heard my computer detecting it .So you gotta make sure that your cable is all the way in.Thats it there you go and merry christmas
3 Suggested Answers
SOURCE: little tikes my real digital camera primary colors downloading pr
The previous email helped me. I held the usb prot into the camera and waited a few seconds and everything worked well. I am using a MAC notebook and the I Photo opened automatically and did fine.
Posted on Dec 26, 2008
SOURCE: How do I turn on
I just got one like this.. Mine wont turn on but in the instruction is says to hold the power button for aleast 2 seconds (the 1st big one on the left hand side). It does take batteries, if you look at the bottom of it the orange part it has 2 screws in it. unscrew them and there is the battery compartment. I am not sure on the charging thing
Posted on Dec 26, 2010
Radio will not go off after shutting off ignition . This started after new battery replacement in 08 Cadillac CTS. The radio used to go off when you opend the drivers door. Now will not go off. How to fix?
Who did the battery replacement? I'd take it back ask them to help you figure it out. Could be there is a security issue so the Radio stays on as an alarm. Many radios have a security code that needs to be re entered any time a battery is changed or other wiring is changed. or Fuses blow. Check Owners manual for troubleshooting and details about radio security code. Dealer may have code tied to Vin number.
Feb 28, 2015 | Cadillac Cars & Trucks
My canon ixus cannot switch on
Make sure the battery is charged. Check the battery door switch and that the battery door fits tightly. You can see the door switch through a cutout in the door frame. It is very small. You can usually bypass it if it is broken. First you have to figure out if it is always on or always off when the door is open. If it is always on then just remove the switch. If it is always off (and turns on when the door is closed) then solder a wire to connect the switch's contacts so that the camera thinks the door is closed.
Note: this solution requires precision soldering and experience
Other possible causes: blown fuse (usually found near the DC in plug), main circuit failure
Apr 09, 2013 | Canon PowerShot SD780 IS / IXUS 100 IS...
Just got truck painted, need wiring diagram to get
Haynes repair manuals would have good wiring diagrams. Or google it, you can find about everything on the internet, but sometimes a problem with too small of print, or maybe my computer skills need sharpening.
I don't know about those wire connections not plugged in. Are you sure they are from the doors? Can't imagine what they would be.
Jan 27, 2018 | 1984 Chevrolet S-10
Dryer doesn't stop when the door is opened
it sounds like your door switch is stuck. you can replace it yourself. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. remove the switch and replace it. hook up your wires. close the top and you should be good to go. good luck
Nov 01, 2009 | Whirlpool GEQ9800P Electric Dryer
Can't remove Blower Motor resistor.
If the plug has welded itself on, your best option is to write down where the wires go (draw a little picture) Then with power off, crush the plug and free the wires. Temporarily, you can wrap each one with tape and just plug them in individually. You can often find another plug in a scrapyard and then insert the wires into the plastic part. Once you see the connectors, you will find that each one has a small tab that holds it from backing out of the plastic plug. Insert a paper clip end to bend those to remove wires from scrapyard part.
Sep 22, 2009 | 2001 Dodge Durango
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I PLUGGED IN THE WRONG CHARGER AND NOW IT WILL NOT COME ON AT ALL. IT WAS A CAR CHARGER ON THE LITTLE ROUND CHARGER PART
I did that to my JVC Super vhs and I fried the internal regulator ckt. I heard a pop sizzle bouy I an ashaimed I should of watched out and put things where they belong when not in use I figured just flop the wires to the adaptors over the door if my desk Weird I alway thaought that the adaptor ends varied in size according to the voltage magnatude and amps
Aug 03, 2009 | Kodak Easyshare M753 Digital Camera
My dryer stopped working. Dryed a load of clothes
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 17, 2009 | Whirlpool Dryers
Little Tykes "My Real Digital Camera"
hi i had the same problem ......then i tired pushing the usb cable all the way in the camera which is difficult as of that flap thing but that worked !!!! hope this helps
Dec 30, 2007 | Cameras
Little Tikes My Real Digital Camera Logo
42 people viewed this question
Top Little Tikes Toys Experts
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
