Question about HP OfficeJet G85 All-In-One InkJet Printer
Printer wont recognize a new cartridge, therefore I can't print
What is wrong with my printer?
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
The following ink tank can not be recognized on mp620?
i would not refill my own cartridge tank with 3rd party if i were you. stick to OEM print carts only . Canon is very pickey when it comes to using OEM cartridges. call Canon direct to get new OEM cartridges 1-866-226-6634
Jan 03, 2012 | Canon PIXMA MP620 All-In-One InkJet...
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Update caused re-fill cartridge not to work
erase all hp software and re-boot with the printer unplugged and the plug the print in and let windows recognize the printer and stay away from new updates you don't need them if the printer works fine an update wont make it better HP updates are insane and politically wrong. GOOD LUCK
Sep 21, 2009 | Office Equipment & Supplies
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
The printer is not recognizing the black print cartridge. It is an official hp black 59 (19ml) cartridge but it still does not recognize it and therefore will not print. My printers is an HP 1215...
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml) C6656A HP 57 tri-color print cartridge (17 ml) C6657A HP 27 low capacity black print cartridge (10 ml) C8727A HP 28 low capacity tri-color print cartridge (8ml) C8728A
Sep 24, 2008 | HP Office Equipment & Supplies
Dell 944 photo all in one printer
Set printer to print multiple copies. Put in less amount of paper. While printer is waiting for more paper, change cartridge.
May 21, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell photo 966 error 1243 incorrect cartridge
is it a refilled cartridge? if it is it wont recognice it u should just buy a new one or keep printing if it lets u because i had the same problem and i had to get a new cartridge because it wouldnt let me print at all
May 02, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark x2550 printer
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Apr 05, 2008 | Lexmark X2550 All-In-One Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
