Question about Asrock AM2NF3-VSTA (4711140874470) Motherboard
Ide install problem
Haveing a problem with a dell precision workstation 650 was using a scsi harddrive that would not load windows (had to keep the windows xp cd in for it to boot )
i decided to add a 500 gb internal pata hard drive while keeping the scsi in as a master ,
i find that the bios sux but besides that the bios will find the 500 gb hard drive , then the computer will boot to windows xp , but windows xp will not find or mount the pata 500 gb hard drive
is this a problem with windows , or a conflict with the scsi / ata hard drives ??
or did i just forget some things ??
  • 983 Answers
There may be some conflict in the jumper settings so just check the jumpers and try to connect it should detect the device ...
if you still persist the problem then just check the ide bus cable there may be some problem in that ...
replace the ide cable and try it ... make sure that the ide slot is working properly ...
regards
-Dileep
Posted on Dec 26, 2008
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Can I boot from a SATA drive and access pre-existing SCSI Drives?
You need to install the driver of your scsi controller for win7/64. Then you'll see your datas on win7.
Jul 08, 2012 | Dell Precision Workstation 670 PC Desktop
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
it will run, but get more ram, your best ram is 2 gig ram to run the game, and all so do a game test on he video card to see if it will lag, there a GTA IV demo out there i belive so try that b4 buing a new ram
Jun 15, 2010 | Dell PRECISION 650
Need internal drive for dell precision 670
You have two options with the WS670. You can use standard IDE (PATA) drives or you can use SCSI drives (up to Ultra320). If you are already using SCSI HDDs in the system, you would most likely be best served by sticking with SCSI for your hard disks and leaving IDE for your optical drives which I believe is the default configuration, but it can be modified when ordering the systems. If you are already using LVD drives, just go ahead and slap another one in of any size. If you want to use IDE, your maximum size will be dicated by the chipset used in the system (information not available on the Dell website).
Jun 09, 2009 | Dell Precision Workstation 670 PC Desktop
J'arrive pas a installer windows xp sur dell precision 670
Aller sur le site Dell et telecharger les drivers SCSI HostRaid: vous obtenez un fichier qui va creer une disquette, a utiliser pendant l'install de XP (appuyer sur F6 au debut de l'install)
Oct 05, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
SCSI Cables Keep Coming Loose!
I use electrical tape for such things. Just wrap it around the cable and then tape it to the tower. It is pretty safe and is easy to remove.
Aug 23, 2008 | Dell Precision Workstation 420 MiniTower...
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Asrock AM2NF3-VSTA (4711140874470) Motherboard Logo
135 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
pankaj rautela
pankaj rautela
Alun Cox
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
