Insignia 27 LCD tv that got a small static shock, now no picture.
When shutting off the tv it got a small static shock and now there is no picture. The insignia label blinks from red to blue but there is no picture. I would like to try and fix this myself if I knew what part was needed. Thanks for your help.
Kim
  • lordkimberly Dec 26, 2008
    Thanks for the suggestion. I had it unplugged for about 45 min and it is still doing the same thing. This is the second time this has happened. The first time it was replaced because it was under warranty. Do you think the power supply needs to be replaced?
    New Friend:
  • 45 Answers
Try unplugging the tv for an extended period of time.(30-60min) plug it back in, that should do it, if not it may need a new power supply,
Posted on Dec 26, 2008
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
I have an Insignia 32'' lcd tv. I shut it off by
when you got off the couch to turn of your set you gave it a static charge which corrupted the CPU try unpluging unit for 30 seconds see it that fixes your problem if not you will need a main board
Nov 18, 2009 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA LCD NOT WORKING
check skart lead connections,and check that the tv is on the right channel,ie av1,av2 ,or skart 1or 2
Jul 30, 2009 | Insignia NS-L26Q-10A 26 in. LCD TV
"zapped" tv (dee7189)
I would need more details on this problem. Does the tv turn on? If so, what do you see on the screen? If you mean by "zapped" that the tv received a lightning strike and does not turn on, it's possible there are several damaged circuit board components. Depending on the severity of the strike, it's possible that just the fuse is blown. I need more details to advise further.
Rick.
Jan 18, 2009 | Insignia NS- 27" TV27 TV
Insignia 27 inch lcd tv gets no video or audio
the most common item that fails with all LCDs is the power invertor or power supply, and that sounds like what your set is needing is the capacitors have possibly failed on the Invertor
Jun 28, 2008 | Televison & Video
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
27" Insignia LCD TV
have the scaler board replaced and the LVDS cable.
Feb 07, 2008 | Insignia LCDTV26 26 in. Television
Screen is nothing but static, BUT...
cheak your cables what inopuut is snowy all or just tv does dvd work
Feb 03, 2008 | Tatung V27DMBX 27 in. LCD Television
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Proscan 27" tv
if you want to eliminate magnetism, you have to degauss the screen, if you don't know how to do that, here is a small guide for that: http://www.wikihow.com/Degauss-a-Computer-Monitor
but that strange shutting down its the transistor... so your best choice is to send it to a repairman to change the transistor..
if you try to do that for your self, you could even get shocked with the electricity contained in the tv... even if its turned off and unplugged..
Dec 22, 2007 | Proscan PS27500 27" TV
Televison & Video Logo
417 people viewed this question
Top Televison & Video Experts
