Question about Philips Magnavox TS3260C 32" TV
TV goes off on its own
I have been having this odd problem with my tv, but I want to make sure it is actually the tv before I buy a new one. I moved into a new apartment in August and since then my TV has been turning off while I am watching it. If I try to turn it back on, I need to press the power button on the remote twice, wait a second, and then a third time. It may stay on then for another hour or go off in ten seconds. I thought it was because of noise from the street because in my old apt it would go off but only when I opened the microwave door. I should say the TV was manufactured in 1989. Okay, I realize that no one should have a tv that old and I do not mind replacing it, but I dont want to get a new one if it is going to have the same problem. Could it be something besides the tv?
  • s smith Dec 06, 2007
    ok so apparently there is a manufacture problem with this 32" TV and magnavox wont take the responsibility of having a recall. My TV is also 5 years old. i bought a 2 year warranty. the service repair man was coming out 3 times a year to fix this problem of it turning off on its on. he even taught me what to do by unplugging it from the wall and waiting 5 minutes. now my warranty has gone out and that little quick fix no longer does the trick. it turn off 20 times in an hour and so we had to move it to the garage and go spend more money to buy another TV. just for grins i will try to turn it on out there and it will stay on for 3 minutes and shut off. what a waste of money and a rip off magnavox!!!!
Most TV's have an 'auto timer' function, accessible from the remote, which allows you to select automatic shut down in half hour increments - so that the TV will turn off (or on!) at the set time.
Your has probably been set to shut down after one hour.
People use function this to automatically create noise and activity while they are away on holiday, or because they tend to fall asleep on the couch! or because they use their TV as an alarm clock.
It's really easy to stray onto this setting on most TV remotes, and then set a shutdown time accidently.
Have a look in your manual under 'timer' or similar.
Posted on Nov 13, 2007
Dust
Posted on May 06, 2007
    Scholar:
  • 135 Answers
It could be one of three things: 1. Your remote is doing wonky things and sending commands to the TV on its own. 2. Something else in the room is sending commands to the TV. 3. Your TV is doing wonky things on its own. To eliminate #1 and #2, try covering the IR (infrared) receiver on the TV. This should be a small red plastic window somewhere on the front, most likely near the bottom somewhere. You can put a book in front of it, cover it with a post-it note, or whatever. After it is covered, try using the remote to confirm that it is blocked. Now leave the TV on for a while -- does it stay on? If so, then it is either your remote or something else in the room. If not, then it is the TV itself. To determine whether it is the remote, simply take out the batteries. Does the TV still turn off? If so, then something else in the room is causing it. It can be something you don't expect -- a crystal ornament hanging in the window moving around that is sending just the right frequency of light, sometimes it is sunlight reflecting off of the blades of a ceiling fan. Sleuthing by moving the thing blocking the receiver can help identify the problem. If the problem is the TV, it is likely going to be too expensive to fix it. If it is the remote, you might be able to replace it with a universal remote, or find a model-specific one on eBay.
Posted on Apr 18, 2007
SOURCE:
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I HAVE A SONY KV 32S40. I HAVE SOUND BUT SOMETIMES NO PICTURE AT ALL. IF I DO GET A PICTURE THEN THE WHOLE PICTURE IS MOVED UP HALF THE SCREEN CAUSING THE TOP OF THE PICTURE TO ACTUALLY BE UPSIDE DOWN....
If the set is more than 10 years old the ceiling point for most sets has been reached, and prices have come down making it more attractive to buy new. To put money in an older set will be gambling with the odds of breakdown in other parts of the tv.
Mar 05, 2011 | Sony KV-32S40 32" TV
I have a brocken panel tv lcd42hd-09 were i kent find a new panel
In most (if not all cases) it is cheaper to buy a new tv as to replacing the broken LCD. The odds of finding an exact match tv with other problems other than a broken screen is not very likely. To purchase a replacement out right is incredibly expensive. If it's not under warrant (or even if it is) a broken screen is not a manufacturers defect and they won't cover it. Just an example. I have a 46" Sony Bravia KDL-46V2500 with a screen damaged by a WII striking the screen. Still under warranty but not covered. Replacement screen is between $4,000.00 to $5,200.00 plus the labor to have theold one removed and a new one installed. NOTwoth the price to replace as two much newerand larger TV's can be bought for that kind of noney. So as far as a broken screen goes even the highend models are throw away's.
Nov 12, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Unable to buy ''TA36N30p''
I've looked every where and I am unable to buy these transistors unless I want to buy 200 of them, what a joke, there are 3 options for these boards:
1. Buy 200 of these transistors
2. JVC sell a new version of this board for £50
3. Buy a fault TV on Ebay and take the parts from that.
I'm gonna go for option 3 then I will have loads of spare parts for any future problems.
Nov 25, 2008 | Philips Magnavox 27MS343S 27" TV
No indication of power what so ever
Yes, a computer power cord is the same.
Without physical sign of damage, it will be hard to induce the movers to cover the problem. You will need to take it into a reputable TV shop and get their evaluation that whatever is wrong is due to the move. Its odd that it failed while off, however of course all these new TVs are not near as reliable as the old ones. Might just be a dislodged connector inside.
Hope Ya Fix It!
Jan 24, 2008 | Samsung PS42P2S 42 in. Plasma Television
Screen problems with HDTV lcd flat panal HP TV
Most likely it'll cost you as much as to buy a new tv.
Jan 20, 2008 | Televison & Video
Hitachi and PS3
Just a note, I am getting ready to buy the same TV. The person I am buying the TV from says the same thing. Not sure of the answer, but If you have the answer now I would like to know. As far as the sound goes, you will have to hook it up separately, the HDMI-DVI (Digital Video input) Video being the key word, it doesnt carry the audio signal. I hope to figure the problem out this weekend when I actually get te TV and try a few things.
Jan 02, 2008 | Televison & Video
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Philips Magnavox TS3260C 32" TV Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
