Question about Dishwashers
Jacuzzi pump on bathtub won't turn off once turned on
Fault on the switch may have water damage
Posted on Dec 26, 2008
Water level sensor
The 'low-water' sensor installed in a bathtub is designed to NOT allow the pump to run without water contacting it.
It sounds as if this is operating as it should.
Once the pump comes on you should be able to touch the "logo" or the on/off button to turn the pump on and off.
If the pump is not turning on/off when the tub is full of water you may be experiencing a problem with the control box under the tub skirt.
Rod
US Parts Center
888-521-6183
Mar 20, 2014 | Jacuzzi Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi spa pump turns on after a power failure
keep a seperate re-chargable battery
Aug 05, 2012 | Jacuzzi Home
Jacuzzi whirlpool bath not working when i turn it on i get a buzzing sound
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Dec 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Bathtup pump issues
buzzing sound on a motor means it has almost burned out. you will need to replace the pump.
May 12, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Heater pump does not turn on Jacuzzi hot tub 325
You should be getting error messages like flo or FLO2. check the voltage to the pump from the board if power is there the pump is bad and needs replacing
Jun 12, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
