My hoppoint washer wf 640 say test, what do i have to do to solve thgis?
Hiya,
It depends on the version of your machine, there are three methods so try them all.
Try pressing and holding 3start/cancel until all the leds light.
Then press start/cancel and on/off until dOFF is displayed.
Machine should now be ok.
If that one doesn't work.
Try pressing and holding the cancel button. Machine should now be ok.
Finally
Press and hold start/cancel, on/off and the top left option button until dOFF is displayed. Machine should now be ok.
Hope this helps.
Thanks
Posted on Feb 20, 2009
Samsung wf 210 front load washer nd code
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
May 21, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Wf 865 water does not seem to be heating up
The cycle does not advance because the temp sensor does not detect enough temperature.
The heating element must be tested using a multimeter , and eventually replaced.
Usually the element is the problem, if element is fine, the temp sensor and the timer control must be checked.
Apr 16, 2009 | Hotpoint Ultima WF865 Front Load Washer
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washer dryer
HI IT ALL DEPENDS ON WHICH LIGHTS ARE FLASHING AS DIFFERENT LIGHTS ARE DIFFERENT FAULT CODES I HAVE A FAULT CODE LIST BUT UNFORTUNATLEY ITS AT WORK & IM NOT BACK IN TILL FRI SO IF YOU CAN HANG FIRE TILL THEN I MIGHT BE ABLE TO HELP YOU OUT
Jul 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
LG WF-764STP
Washer capacity- 7.2kg · 8 Washing Programmes · Child Lock · 53 cm Wide x 54 cm Deep x 85 cm High
Sep 12, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
