Question about Home
Kohler 81100 Pressure-Clean Flushometer Toilet
My toilet is flushing with progressively less pressure. I have checked, plunged, and snaked the line from the toilet. The problem seems to be the toilet itself. Is there a way to re-pressurize the tank? I HATE my Kohler 81100. And I've lived with this piece of s*** for years, having to flush 2-3 times after each use, because it was so expensive. Now it runs for almost 30 minutes after each use, so I have to use another bathroom altogether.
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
  • 1 more comment
  • arht Oct 19, 2010
    I was about to scrape my Kohler 81100 Pressure-Clean Flushometer Toilet due to loss of pressure. I am glad that I followed above instructions. I got 100% result. Thanks for your great tip which saved me a lot of money and aggravations.
  • pamarie Jul 23, 2011
    My husband followed your suggestion and held down for 3 minutes for good measure and it seemed to do the trick. We'll keep an eye on it. Thanks so much!
  • Anonymous Jan 19, 2017
    Just tried it and is seems to have worked! Jan 2017
    Problem Solver:
  • 14 Answers
You solved the problem yourself! This toilet is junk! I suggest replacing with something that works such as the Toto Drake.
Posted on Dec 27, 2008
WHERE CAN I BUY KOHLER 81100 FLUSHOMETER REPLACEMENT SYSTEM
you are in the toilets and bidets catagory so go to a plumber supplier shop and ask then what unit will replace the item
Sep 23, 2016 | Kohler Home
Kohler toilet not flushing completely
You have a partial clog, as if someone tried to flush paper towels or something that shouldn't have gone in the drain.
Try plunging, first, then a toilet snake, or you may have to get a pro to pull the toilet off the floor and run a larger snake if it's further down...
Mar 12, 2014 | Home
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
Kohler 81100 water keeps running into bowl
If it is installed correctly then due to age, the seal may be damaged.
Dec 12, 2017 | Home
I have a Kohler 81100 pressure flusher that came with the house when I bought it. Can I remove the pressure system out of the toilet tank and replace it with a regular flushing system?
As a general rule, no However contact Kohler, they may give you a discount on a replacement toilet, as there have been some recall issues.
Jun 05, 2011 | Home
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
This is a commercial toilet with a g-2 sloan valve on top. The amount of water dispersed is fine, but there is something wrong with the throat of the toilet, I think. The drain action is somewhat slow...
The blockage MAY be beyond the length of the snake you used. Once I had a blockage that required 145 feet of snake. ALSO the vent could be plugged by any of several things, including wasp nests.
Nov 04, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Hi DavidofCA
I am with the Kohler Customer Care Center. My name is Mike. My phone number is 920-208-4622.
If you still need help with this issue please contact me. Thank you
Nov 03, 2008 | Cuisinart CPT-65 Custom Control Total...
Home Logo
3,254 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
