Question about Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive
Flashing leds on both the power adapter and the external drive
Although I have shut down and changed locations of my external hard drive several times before, today when I connected the power cables both leds on both the power adapter and the external itself were continously flashing and of course my operating sysytem didn't recognize the external drive as usual. I have checked to make sure that all connects are fully engaged. What can i do to correct this problem?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
Assign a drive letter for the External.
Right Click on My Computer
Scroll to Manage
Select Disk Management
Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, you should see your External with your new drive letter assigned to it.
-mk3ride
Dec 31, 2010 | Western Digital My Book Essential 1TB...
The Green Ring just keeps flashing, when plugged in On my computer it does not have a Drive Letter and when turning off the computer I have to Unplug My Book Hard drive for the computer to shut down, the...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 05, 2010 | Western Digital Computers & Internet
My usb external Buffalo ministation is not been recognised on my pc and the LED light is flashing green and orange
* USB cable
Nov 04, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
External HDD Shuts Off
Could well be the power adapter. They seem to fail quite often. AFAIK, it is a 12V / 2A adapter, so it should be easy to find a suitable replacement. Just make sure that it is a switching adapter with stabilized output voltage.
Mar 19, 2010 | Western Digital My Book Essential 1TB...
First problem is i do not know how to power it on
some external drive have power switch that you can power on and off. some do not. you just have to unplug the power adapter.
how many led indicator you see in your external? if only one, then maybe its just reading the file in your external hdd.
Mar 02, 2010 | Computers & Internet
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
My Dell Inspiron 510m laptop will not start up. One of the 3 lights next to the sart button turns on and flashes for several seconds then goes off. How can I fix this problem?
Those diagnostic LEDs indicate a No POST situation. Most likely, the motherboard, memory cards or hard drive is the root cause. Please contact Dell Tech support, they have the list of the meaning of diagnostic LEDs
Jun 14, 2009 | Microsoft Windows XP Home Edition
Flashing LED light but not working
Unfortuntly, this caused the drives power source to be exceded and damage the drive or circut board. If you know someone that knows computer well, have them or yourself take the hard drive out and manually connect the driver to a computer and extract your data, if the drive is not damage that is, there is know way to know for sure until you try to connect to a PC directly. Or, purchas another USB external housing.
Feb 11, 2009 | Toshiba 120GB USB 2.0 Portable External...
Simpletech external simple drive model 96300-40001-001--flashing blue light
do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Aug 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
61 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
