Question about Maytag Neptune MDE6800A Electric Dryer
Dryer cuto off
The dryer comes on runs about 20 - 30 seconds and cuts off. I have disconnected vent from both wall and dryer and problem remains. I have vaccuumed both rear of dryer and lint area and problem continues.
  • lehunghao Dec 17, 2008
    My mytag model is LDG8600AAL, which lately had problem that flame of gas was cut off after 30 second to 60 second. I did replace themal cut off but it won't help, Please advice.
  • 87 Answers
You probably have a bad thermistor located on the blower housing, a small black plastic item.
Posted on Jun 08, 2007
SOURCE:
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
Gas dryer doesnot get hot enough flame comes on for 20 seconds then shuts of continually cyculing
You have a air flow restriction. To determine where it is you will need to run a simple test. Disconnect the vent system behind the unit, if the dryer improves, your problem is in the wall, if not the problem is in the dryer. You will need to determine where before reacting to a repair. Most of the time its in the vent system outside of the dryer itself.
If you still have issues get back to me and I can direct you further. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer model # 6672. Comes on and gets hot, but after a few seconds, the heat cuts out.
disconnect vent tube and run dryer, as it sounds like the vent is restricted, Tim
Mar 12, 2011 | Kenmore 600 6965 Electric Dryer
My kenmore dryer 66512692 runs for approx. 10 minutes and cuts off. I can come back to it usually a couple of hours and it will run for another 10 or 15 minutes and stop. It will complete the Air Dry...
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
wer
Dec 25, 2010 | Kenmore Dryers
The dryer won't dry the clothes. cooling light comes on. cleaned the vent looked at the gas connection etc..
You have a problem with the exhaust vent in the wall. Best way to test is to disconnect the vent from the wall and run the unit with a normal load. If it dries normally, you will need to have the exhaust vent cleaned professionally.
Good luck
Sep 25, 2010 | LG DLGX8388 Gas Dryer
The dryer will run for a long priod of time (hours) without shuting off and the clothes remain wet.
The main cause is a plugged exhaust vent in the wall. Try disconnecting the exhaust vent from the wall and run a normal load. If the load dries properly, then you will need to have the exhaust vent professionally cleaned.
Good luck
Sep 21, 2010 | Dryers
Hi My dryer has to run twice before my clothes are dried. What do you think is the issue, and how can I fix it?
One of two things, first heating element going bad. Second dryer vent is clogged with lint, causing moisture not to escape. I say problem is my second choice. Disconnect dryer vent and vacuum out dryer, then clean out vent all the way to the outside. Lint builds up on walls of vent, causing problem you have.
Aug 18, 2010 | Kenmore Dryers
Dryer heats up, but won't dry clothes well
Also check your vents in the machine and the wall. Pull the machine away from the wall and feel how strong air is coming out. After cleaning the machine, run it one load disconnected from the wall, and one load connected. This will tell you if your wall vent is clogged.
May 09, 2009 | Dryers
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Maytag Neptune MDE6800A Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
