Question about Fisher 9925 Shelf System
Volume control stuck
Volume comes on full blast when turned on
  • lowblade02 Feb 18, 2009
    I have the TAD-5060 and my volume comes on full blast when you turn it on.
**** your radio
Posted on Jun 07, 2009
I have to turn the sound up full blast when watching recorded programmes. It is fine when watching live tv so not sure if it is the tv or the Sky box, can you advise please.
Mate does your sky box have a volume control as well as your television, I have a sky box(fox-tel)with volume control as well as the television volume control.... I have the television volume up full and control the volume through my sky box(fox-tel).... Hope this helps... CHEERS...
Mar 12, 2016 | Televison & Video
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
Volume control on in-dash unit not working properly
Sony CDX-GT300 volume control stopped working. Radio is either on full-blast, or you have to turn it off. Any solutions? Thanks!
Aug 03, 2008 | Car Audio & Video
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv rca televison model DZ7649 Entertainment series
  • there is a loose contact in volume control or switch.
  • clean volume control with cleaning chemical & change volume switch.
  • hope this will help.
Oct 12, 2007 | Televison & Video
Fisher 9925 Shelf System Logo
115 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
