-   i have a gt 704 wg, i can't open internet explorer to set the router up on my gate way there is no internet light and the dsl light is flashing green the power light is solid green as is the ethernet, but the internet light is out and the dsl light is flashing green -   lmbcarmen
Router setup You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem. Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
how can i replace the antenna on the netgear wgr614v9 router, with a high gain, or a directional...
(More)
HOW CAN I REPLACE THE ANTENNA ON THE NETGEAR WGR614v9 ROUTER, WITH A HIGH GAIN, OR A DIRECTIONAL ANTENNA. THE ROUTER IS WORKING FINE, I JUST WANT HIGHER SIGNAL STRENGTH WITH IN MY THREE STORY HOME. THANK YOU, RALPH
I recently purchased a Belkin N150 (during the walmart black friday sale) and it has been running...
(More)
I recently purchased a Belkin N150 (during the walmart black friday sale) and it has been running fine since I pulled it out of the box. Three times now, when trying to connect to my router with my wireless laptop, the computer does not connect to the router. The light on the router stays off until I pull the power cord for 10 seconds and a hard reset is done. I tried going through settings but I can't figure it out. Is this my router or my computer which I just recently put Windows 7 on.
WRT610n router power led light blinks and i cant connect to internet or the linksys 192.168.1.1 web...
(More)
WRT610n router power led light blinks and i cant connect to internet or the linksys 192.168.1.1 web pg
