Question about Samsung DLP HL-P5663W 56" TV
Samsung S5687 w/hl shuts off after 20 seconds
The TV has worked fine for the 13 months since I bought it. Xmas morning I turn the set on and 20 seconds later it, the screen goes black, then a few seconds after that, the set shuts down. I then get the three lights on the front blinking. I tried unplugging for awhile and messed with the little blue switch by the bulb door. The one fan I can see still runs. The same scenario plays out every tme i turn the TV on. The TV gets alot of use (8-9 hrs /day) but would have thought the bulb would last longer. Do you think its the bulb or should I call a Tech?
    Top Expert:
  • Samsung Master
  • 76,016 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 29, 2017
SOURCE: Samsung HL-P5663W, picture goes black after some time
I fixed it. Went back in after a twenty min. break, figured if it's broke I can't break it again, might as well try to fix it(out of warranty, so much time on 1st. bulb, after fixing I found out had 8463 hrs. on 1st. lamp! WOWW most i've seen on any strings out there,and I'm really cheap and inquisitive) But this is how I did it. pulled off covers. looked around pulled light box out checked connectors and resistors visually for burns, none found, then I see a clear plastic sleeve covered group of wires it was plugged up at the ballast where i was working earlier but not the other end, so i looked around for the plug to insert it, couldn't see any where. I felt on top of a silver polished panel w/holes allover, there on top, at the right side of the silver panel was a plug for it. I plugged it in by removing fan and cooling fin assembly, for room to work(and good chance to clean dust from the fins and fans. I tilted silver panel down to see the top, after some removing spring loaded screws holding cooling fins, (the screws ave very light spring tension and won't pop out, I swear, keep track of springs for reassembly later) plugged it in(only goes one way, don't force it, flip over if it doesn't fit nicely) replace all removed parts in reverse order and reinstall covers, plug up, and mine powered on almost instantly. After that and spending 2 hrs. online trying to go through all the strings everywhere about these problems. It came down to trial by fire. I hope this helps, reply if it doesn't.
Posted on Nov 15, 2007
ladywinn
  • 5138 Answers
SOURCE: Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Posted on Feb 20, 2008
IB4G2008
  • 3587 Answers
SOURCE: Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Posted on Mar 24, 2008
  • 108 Answers
SOURCE: Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Posted on Jan 06, 2009
SOURCE: samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Posted on Apr 10, 2009
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
TV goes off after 20 seconds Samsung HLS5086wx
First Take off the Lamp Door and replace it back the way it was secured with all of the screws. Doing this will reset the safety interlock switch which heats up and opens the circuit causing the set to shut down. After doing this and the set still shuts down check the lamp. Depending on the amount of hours on the lamp it may be a bad lamp. They will fail with out any obvious signs. If the set shut down and goes straight to the Stand By condition then you have a bad Power Supply. If you hear a whining or buzzing sound then you have a bad Color Wheel.
Apr 11, 2010 | Samsung HL-S5086W 50" HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LCD TV LE32A450 turns off by itself and then turns on
i dont know where are you from but in europe samsung gives 2 years full quarantee!try to an authorized center!withthe set give to them the quarantee leaflet and the bill from the shop!
Aug 18, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung DLP HL-P5663W 56" TV Logo
64 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
