Question about Kirby Ultimate G Bagged Upright Vacuum
Vacum will not pick up
I have a new carpet and my kirby will not pick up,it spits out the fuzz balls from the rug. It was working fine until the new carpet. 2 belts have broke because of this.
  • Kirby Expert
  • 324 Answers
Due to the way carpets are made - new carpets sometimes have a lot of loose fiber. This is NORMAL and it may take 3-5 times to vacuum the carpet till it goes back to normal. Spitting out fuzz balls is a bit weird. Make sure you have the belt installed right - see video on www.goodvac.com. but the fact that belts keep breaking I am assuming that you have them installed right. Give it a few more belts and if the problem presists - let me know.
Rocky
Posted on Dec 26, 2008
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum doesnt pick up very well any more
Larry Kessler:
Unplug the vacuum and lay it down on the floor upside down on some newspaper. Remove the vacuum head foot plate with a Phillips head screwdriver. Remove the beater bar and belt by pulling straight up on the beater bar. Pull the end caps and bearings from the ends of the beater bar... it may take a two-grunt pull to remove them, or CAREFULLY use a screwdriver to pry them off. Remove the hair, carpet fibers and other gunk from the ends of the beater bar, bearings and end caps. Pour (or spray) alcohol on the bearings and spin them until they spin freely. Dry the bearings so there is no alcohol in them.
Put a few drops of light machine oil in the bearings, (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure the bearings spin freely. Now would be a good time to check the vacuum head opening and the hose for clogs. Reassemble the end caps and bearings to the ends of the beater bar and reinstall the beater bar assembly (with a new belt) in the vacuum head. Reinstall the foot plate, and your machine should pick up fuzz balls the size of Michigan!
Feb 15, 2013 | Vacuums
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
Can I use Rug Doctor steam cleaner shampoo in my Ultimate G series Kirby carpet shampoo system?
The answer is no. This type of shampoo doesn't work as well in the Kirby. It should be dry foam shampoo only.
Nov 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
To much water going out when shampooing and not picking any water up.
Follow instructions HERE.
If it is soapy water NOT FOAM coming out - make sure suds screen is installed.
If you get mountains of foam and it is absorbed into the rug by the time you are ready to pick it up - maybe you dispensing entire tank of soap before you go to pick it up. Do carpet in 6-10 foot wide sections.
Some carpets (especially Berber) are not easy to get the foam off...
Mar 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria doesn't pick up visible dirt
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Dec 08, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
112 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
