Question about Sentry Fireproof Safe
Sentry safe model SB0100 wont open with three digit com
Just bought this safe it was locked manuals are probibly inside safe tryed the 3 digit com that is on the sticker on the front of the safe but it still wont open
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
  • 360 Answers
SOURCE: sentry digital fire safe
Information is available at http://www.sentrysafe.com/index.aspx
Posted on Feb 05, 2009
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
SOURCE: sentry safe ob0100 wont open with 3 digit com
A1 locksmith say's If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Posted on Aug 09, 2010
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
Sentry S 3110. Combination lock with 3 numbers. How do I open it?
First insert the key into the lock, if there is a keyhole, and turn it until the plunger pops out. (You must have the key to unlock the safe for the keyed version of the safe.) Remove the key.
Set the dial to zero. Turn the dial to the right (clock-wise) three times (pass zero three times) then stop at the first digit in the combination. Turn the dial to the left twice and stop at the second digit given in the combination. Turn the dial to the right again and stop as soon as you reach the third digit. The safe should open.
Sentry has the manual available for the S3110 safe on the product page: http://www.sentrysafe.com/Products/36/S3110_FIRE-SAFE_Home_Safe . The direct link to the manual is http://www.sentrysafe.com/pdfs/OwnersManuals/514472.pdf . The directions for opening the safe are on page 2.
If you do not have the key and your safe has a keyhole, you probably need to contact Sentry or a locksmith.
I hope this helps.
Aug 30, 2015 | Home Security
Just got a home sentry safe, locked instructions inside with combination that came with it when i bought it, is there anyway to get inside it? please help
My sentry safe opened when I followed the manual.
If yours is the same as mine (Keypad, fingerprint), press 99, clear, 2004, enter, and it will reset it to factory conditions.
Nov 21, 2009 | Sentry Fireproof Safe
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
Aug 25, 2009 | Sentry Fireproof Safe
Sentry safe ob0100 wont open with 3 digit com
Jan 01, 2009 | Sentry Fireproof Safe
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
Safe won't open
try this link
http://questions.askit.com/askit?token=9a2e3e24f3f8e6c4299bc15e7424dcb&topic=7.65019126E9&cmd=ShowAFaqCmd&question_id=77384.0&jsessionid=1476781100484771587
Apr 23, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
385 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
