Please help... my mobo cant detect my processor, when i check for my processor model in dxdiag it only detects amd nknown processor
Additional question, can BIOSTAR NF61S Micro AM2
a
AMD dual core X2 7750 2.7processor? which is a am2+ socket processor.
SOURCE: i cant get any audio
http://www.nvidia.com/Download/index.aspx?lang=en-us
This is Nvidia's link for current downloads. I have entered your info but will outline.
1-Product type-click on arrow on right, scroll to GeForce, click and select.
2-Product series- click on arrow scroll to "GeForce 6 series" and select.
3-Product- click on arrow scroll to GeForce 6100 and select'
4 select you o/s and language., then click "Search" this will give you your latest drivers.
You must first uninstall any Nvidia software before doing this.
I would do this if you haven't updated lately or ever.
Your audio as far as I can see is Realtek. If you have a speaker icon on your taskbar at bottom of screen. Left click on it. Make sure volume is up.
Now right click on it, a window should come up and there should be "playback devices", right click on that. A window should come up showing Realtek. Right click on that and a window should come up. In that window you should see "enable" or "disable". If it says enable, click on that, if it says disable, leave it alone. If you had to "enable", this should solve your problem. Left click on speaker icon again and check volume. I hope this helps.
SOURCE: I have a problem with
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and
are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
the leads from your
