Question about Braun MULTIMAG SlideScan 4000
Mac can't find driver for multimag 4000
Loaded software 4 times supposed to work with Macs have photoshop elements installed
  • 13,433 Answers
Hi, yes the device is supported on Mac: OS X 10.1.5 or higher what is the current mac os installed on your mac?
Posted on Dec 26, 2008
I CANT INSTALL
Adobe Photoshop CS2 have some system requirements to be meet before installation, the requirements are listed below: (if you don't meet any of the minimum you should upgrade your hardware to install this software) (hopes this helps)
Processor
  • To run Photoshop CS2, PC users should have one of the following processors: Intel Centrino, Xeon, Xeon Dual, Pentium III or a Pentium 4 processor.
    Mac users who want to install Adobe Photoshop CS2 need at least a PowerPC G3, G4 or G5 processor.
Operating System
  • Photoshop CS2 requires at least a PC that runs Windows 2000 or Windows XP. Windows 2000 users need Service Pack 4. Windows XP users need Service Pack 1 or Service Pack 2.
    Mac users can run Photoshop CS2 on OS X versions 10.2.8 through 10.3.8 at least. However, Adobe recommends versions 10.3.4 through 10.3.8.
RAM
  • Both PCs and Macs can run Photoshop CS2 with 320 megabytes of RAM though Adobe recommends running the program with at least 384 megabytes of RAM.
Hard-Disk Space
  • Before installing Adobe Photoshop CS2 on a PC, make sure you have at least 650 megabytes of hard-disk space free.
    If you are installing CS2 on a Mac, check to make sure you have at least 750 megabytes of hard-disk space available.
Monitor and Video Card
  • Adobe Photoshop CS2 works best on monitors with a resolution of at least 1024 by 768. A 16-bit video card is also required. These requirements apply to both PC and Mac users.
May 27, 2011 | Adobe Photoshop CS2 for PC
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Cannot access help on Adobe Photoshop Elements 6 for Mac
There are a couple of solutions posted on Adobe's web site about this specific problem. Check this link out:
http://kb2.adobe.com/cps/402/kb402707.html
Sep 13, 2009 | Adobe Photoshop Elements 6 for Macintosh...
Can't load elements 6 get error message to contact Adobe
you have an older install in the system that the activation was suspended, have to delete all the preferences in the system for this program
Jul 26, 2009 | Adobe Photoshop Elements 6 for Macintosh...
Same problem I have
The software that you did not get usually isn't necessary. MACs just recognize and download the files, especially easy if they're quicktime. I have a Sanyo digital video camera, and Nikon & Canon still cameras. I never install their software because I can use much better stuff like IMOVIE or IPHOTO and Photoshop. Just plug it in. Drag it to the desktop once your MAC recognizes it.
Jul 22, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Download
HI ^^
DOWNLOAD THIS FULL VERSION ( MAC )
Adobe Photoshop CS4 [k]'d Patch - Intel Only
Note:This only works on INTEL-BASED Macs only.
Quote: 1. Select/Drag the Photoshop CS4.app onto the window/drop zone.
2. Wait for progress.
3. ???
3b. (Wait for it....)
4. PROFIT!
-Zenova Code:http://rapidshare.com/files/156333917/MiRROR.ZeNoVa.dmg
IF YOU WANT XP VERSION JUST LET ME KNOW
PLZ RATE IT FIXYA ^^
Jun 01, 2009 | Adobe Photoshop CS4 for Mac
Problem loading Photoshop Elements 6 to Mac from CD-Rom?
You probably received a faulty disk, just return it to Amazon and ask for a a replacement.
Regards -- Joe
Feb 06, 2009 | Adobe Photoshop Elements 6 for Macintosh...
Mac can't find the driver for the Multimag 4000 - using cyberview
Hi
lets start with what mac system you have there? the device is supported on Mac: OS X 10.1.5 or higher
Dec 26, 2008 | Braun MULTIMAG SlideScan 4000
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Open Questions:
See all Braun MULTIMAG SlideScan 4000 Questions
Braun MULTIMAG SlideScan 4000 Logo
71 people viewed this question
Top Braun Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
