Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer and refrigerator will not get cold - fan runs but not ver
Whirlpool sise by side not getting cold or freezing - can hear fan running but not very loud
  • Anonymous Dec 27, 2008
    refrigerator will not get cold, freezer is fine
Have checked every thing, can we put freon,and how do we do this?
Posted on Mar 10, 2009
  • 198 Answers
You will need to check for frost accumulation in the freezer section. The rear panel inside the freezer will need to be removed. If there is frost either the defrost bi metal or the heater are open. If both are ok the defrost control needs to be replaced depending on the model some defrost controls are electronic some are mechanical.
Posted on Jan 05, 2009
Side by side refrigerator
produce freezes at 35 f also make sure you fan in your freezer is working. when you hear the fridge running open the freezer door and see if fan is running. if not replace the fan or call for service. if your fan is running adjust the temps to a 37 for fridge and 0 for freezer.
Jan 30, 2012 | Whirlpool Refrigerators
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
Highpoint sise by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 13, 2010 | Hotpoint HSS25GFP Side by Side...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Refrigerator is not getting cold
fan motor running in freezer?- put unit in defrost the timer has a slotted set screw turn clockwise the unit will go into defrost the electric heater will start/ the fan in freezer and compressor will stop do a few times to get rid of ice if does not go into defrost a couple of things maybe wrong the first thing to check is fan motor in freezer should be running if not everthing will freeze
Jan 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
207 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
