Question about GE DBSR453EBWW Electric Dryer
My GE Driver will not heat
My GE Model DBSR453EB3WW is not heating to dry the clothes. It is blowing properly, turning and working but not heat. WE have installed new dryer hose, and cleaned all lines. But still not heat. This dryer is only 2 years old and is used daily.
HELP
  • Anonymous Dec 27, 2008
    i have same problem
  • Anonymous Jan 29, 2009
    to check the thermostats Hi limit, where do i find this on the dryer?
  • 126 Answers
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Posted on Jan 28, 2009
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
My GE Dryer.. serial number GL 733 568A. Do not dry clothes, everything else work, except getting hot enough to dry. The dryer just blow cool air..
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | GE Dryers
My dryer is turning blowing everything but getting hot to dry the clothes. what parts should i order? We have kind of thought it might be the heater assembly?? Any help appreciated. Model# DPGT750EC1PL ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 23, 2010 | GE Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 06, 2009 | GE Dryers
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryer dbsr453eb3ww
sounds like electric heating element issue to me. Your gas dryer doesn't have electric heating elements which might explain your problem
Jun 26, 2008 | GE DBXR463EBWW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
318 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
