Compaq V4325 power issue
I have a Compaq V4325 US laptop that keeps powering down unexpectedly. There is no warning it just turns off as if someone had flicked a switch. Sometimes the computer will not even complete booting before it turns off and there is no way to use the computer, at other times it can work for hours without issue.
    Master:
  • 413 Answers
Most likely it sounds like an issue with the motherboard the only thing you can do in this case is return it to the manufacturer for a replacement. Sorry
Posted on Dec 26, 2008
My Dell windows 10 will not log off circle keeps spinning
Usually, this means that something either running in the background, or an app, or an update trying to install is keeping the pc from shutting down. Wait about an hour if it is still just sitting there spinning you may want to do a hard power down.
WARNING forcing your pc to power off may have unexpected results not limited to unable to power up and lost data.
To force the pc down press and hold the power button until the unit switches off. Immediately restart the unit and do a thourough review to ensure proper operation.
Aug 20, 2016 | Dell Inspiron Computers & Internet
Why is my acer aspire shutting down
If you're running Windows go into Control Panel and check Event Viewer. Look under Windows, System, and look at any Warnings (Yellow triangles with exclamation marks) If you're seeing error codes you can look those up; if "unexpected shutdown" shows up a lot your laptop could be overheating or it may be a power issue.
Aug 27, 2014 | Computers & Internet
I'm trying to fix a Compaq R3202US model laptop. The computer unexpectedly shuts down and sometimes has issues even coming on by pressing the power button. I have already changed the HD and installed 512MB...
It sounds like it's overheating. I would open the bottom panel and see if any of the heat sinks seem detached from any core components like the processor or gpu.
Mar 11, 2011 | Compaq Presario R3202US Notebook
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
Advent 6651 notebook turns off
This is a total long shot, but could there be some of the original packaging attached to the battery? The 'brand new' aspect of the laptop made me think about this.
It sounds like your computer is powering directly from the charger, without any of the charge going into the battery. If there was a small plastic cover over the contacts on the battery, it may explain this probem.
Otherwise, I would look towards some other battery issue.
There could be a power saving feature somewhere causing this problem, however there's normally some sort of warning about this, rather than an unexpected and instant shutdown.
Sep 30, 2009 | Computers & Internet
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Acer 5520 power shutdown
Possible heat issue. Check the cooling fans and see if theyre running. Usually one on the bottom, back or side of the laptop. Make sure that the cooling vents arent blocked during use.
Apr 04, 2009 | Acer Aspire 5520-5908 Notebook
Error warning when first turning laptop on
If you just bought it from a store, take it back and they should fix it under warranty.
Mar 07, 2009 | Acer Aspire 5735 Notebook
Wont turn on
At this situation we can try power drain.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue. If the issue persists, then the only option is service center.
Jun 08, 2008 | HP Compaq Presario C500t Notebook
Compaq presario V2000 power off unexpectedly.
There are quite a few laptops and towers (my e-machine) that is not compatible with service pack 2. However, they are compatible with service pack 3 release candidate 2. Down towards bottom of page, choose which language.
Apr 05, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
