Question about Brother MFC-8440 All-In-One Laser Printer
8420 hinge Hi I saw your inquirey in Fixit about the 8420 hinge. Did you ever find out where to order the part. I have a couple of machines and need to do the same repair. Thanks for your help pellettiere@yahoo.com
I have found this item listed for prices ranging form 12.00 to 34.00 +S&H.
Posted on Jun 07, 2009
    Champion:
  • 320 Answers
The hige must be ordered through a authorized brother dealer. the hinge sells for around 59.00 plus shipping i am sure that u could install it
Posted on Jan 14, 2009
Not working
There are various causes of failure but the checks should be carried out in this order, you will probably need a continuity meter or multimeter to trace continuity from the plug to the motor:
Check overload circuit breaker on saw hasn't tripped. This may need a couple of minutes to cool down.
If plug is rewireable check for loose screws at plug pin terminals, loose fuses etc.
Wires in power flex breaking, usually at plug or where flex enters machine.
Faulty on / off switch or loose spade terminals on switches or faulty relay on switch.
Worn out brushes.
Armature or field coils of motor going open circuit.
Mar 05, 2011 | Bosch 4000 - 07 Electric Table Saws
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
I have a #1030103 Craftsman band saw with a broken upper pulley axle hinge. ware can I find
I don't know if this will help but I remember seeing a site that talks alot about older saws like the 103. it was under antique/vintage bandsaws. also bobvilla.com may help. Good luck its a good saw.
Oct 06, 2010 | Craftsman Saws
How can i get a guard for this table saw the dw 746
You can order them at www.dewaltservicenet.com.
The DW746 and DW744 use the same guard assembly, if you're talking about the hinged guard over the blade.
Mar 29, 2010 | Dewalt DW746 10" Woodworker's Table Saw
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
