Question about Dell Optiplex GX110 (2909T) Motherboard
Optiplex 745. Want to add second sata drive. Put in place and
The system said it was adding an IDE device. I put the sata cable into the last and only left of the SATA attachment on the mother board.
  • beerup Dec 26, 2008
    I have one hard drive at SATA0. SATA1 is attached to a DVD drive. SATA4 is attached to DVD R/W. I do not see a SATA2 or SATA3 on the board. I attached the second hard drive to SATA5. After the system started, the drive is not seen.
    Scholar:
  • 172 Answers
Go into CMOS to check that your sata ports are enabled.If not, then enable them and make sure you save the settings on exit from CMOS. Make sure your SATA drive cable and the drive power cable is attached correctly to both the drive and the motherboard. Reboot the pc and the system POST (power on self test) should see all of the attached hardware including the ide and sata drives. Depnding on which port you have plugged the sata drive into it will appear as sata1 sata2 sata3 or sata4
Posted on Dec 26, 2008
  • 837 Answers
Are there any IDE devices in your system? I have seen some motherboard/BIOS identify the IDE devices into the SATA scheme.
Try disabling the IDE controller temporarily to verify .. If the SATA device then shows up you know that you are dealing with IDE/SATA conflicts ..
  • 916 Answers
Check to make sure that you can see the driver in computer management in administrative tools if you cannot check the cables they might have gotten knocked loose
    Top Expert:
  • Dell Master
  • 83,850 Answers
I donot understand your question?
  • Dell Master
  • 13,433 Answers
Can you clarify what the actual problem is? some motherboards can be configured to use SATA in place of IDE secondary for example.
  • Ekse Dec 26, 2008
    Look into bios and make sure all sata ports are enabled. optionally restore your bios to defaults or reset it.
How to installing the windows 7 in optiplex 745
Installing windows 7 isn't difficult. First, you need the disk to install it from. If you don't have that, Microsoft no longer sells this version, so it will be harder.
If you want to keep your programs and data, there is a package, "PC Mover" that you can buy that will help you preserve all your data and programs. I've used this many times to help upgrade systems like yours.
Nov 09, 2014 | Dell OPTIPLEX 745 PC Desktop
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
Hi i have a dell dc550 motherboard and want to put a 1 TB hard drive on it can I ?? The computer is a optiplex 170L
Yes you can. If you are adding a second hard drive, don't forget that you will need to purchase an additional SATA cable.
If you are replacing your current hard drive, you shouldn't need any additional cables.
Download the hard disk drive's manufactures tools software to setup your SATA drive. Make sure the bios see's your 1TB drive listed. If it is going to run your operating system check the Boot section in your bios & make sure it is listed in the boot order.
Cheers!
Mike
Oct 12, 2009 | Dell (2336V) Motherboard
I want to install a seond hard drive in computer
can you please open up the CPU and check one thing? Is there any Free port in this cable? One end will be connected to the motherboard and two others to (1)CD/DVD rom and (2) Hard drive.
If there is free, surely you can add one. Please then look for a place where you can place your (ATA not the sata one) harddrive.
Apr 05, 2009 | Dell Dimension 4300S (Refurbished)...
Second harddrive
Make sure its jumper is set as slave, if you have a 40wire ribbon cable, and cable select if you are using a 80 wire ribbon cable, if it is on the same ribbon cable.
If it is on the second ide cable, by itself keep it as master.
Jan 15, 2008 | ASUS M2N-MX Motherboard
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Dell Optiplex GX110 (2909T) Motherboard Logo
1,213 people viewed this question
Clive
Clive
Alun Cox
