Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Noisy spin cycle
I bought a reconditioned Bosc WFMC1001UC washer. It is very quiet until it reaches the spin cycle. Is it NORMAL for the spin cycle to be so noisy? I thought this washer was known for its quietness and now have to deal with this spin cycle noise. I am waiting for the owners manual as I did not receive one when I bought this. Also, is it normal for a larger load of clothes to take so long and have SEVERAL rinse cycles in it? This last large load I am doing now is taking over an HOUR to complete. Any help would be appreciated. I am now guessing that these problems are why this washer was returned to the store where I bought it. Thank you for your help.
  • bbjhighacres Dec 27, 2008
    Well, it just seems loud enough to hear in other parts of the house. We leveled it today and ran a spin cycle but without a load of clothes in it. We will try again with clothes tomorrow. It was only off a little bit on the level and we received the owners manual today and followed instructions for the leveling.It was a lot quieter but that was without clothes so don't know what to expect next time. Could the slightly unlevelness have caused it to be noisy the first few times we used it? Thanks!!
  •  Sherman
    Sherman May 11, 2010
    how loud are we talking
  • Bosch Master
  • 3,463 Answers
It would be noisier than normal if it was not level.
Best way to tell if it is noisier than normal is to spin the drum by hand, there should be little or no noise from it.
If it is noisy or rumbling, or feels rough, then I would suspect that the drum bearings are worn and noisy.
An hour to complete a wash cycle is not abnormal, and they do do several rinses.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
My bosch 100 nexxt will not spin or complete a full cycle
does it spin and no pump, or pump and no spin or neither does it come to end of normal wash and stop before spinning.
Dec 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Our washer has a loud vibration while spinning. The washer is level.
It could be either bearing failure or the support arms that hold the wash drum are failing. If it is relatively quiet when in the normal wash cycle but noisy only during the spin cycle, means that the bearings have failed. It's an expensive job to replace since you need to tear the entire machine apart to get to the outer tub. Another reason is that the manufacturer does not sell you replacement bearings but you must buy the outer rear tub. Get a few estimates before deciding whether to repair or replace.
Feb 12, 2011 | Whirlpool WFW9200S Front Load Washer
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
We heard a large BANG and now it is so noisy
The rear bearing in most front loaders lasts an average of 5 years under normal usage. Spin the drum manually with your hand and seee if it is nice and smooth and quiet. If the bearing is ok it is probable that 1 of the shocks is broken on the bottom.
Mar 18, 2010 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
448 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
