Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
My vacum power head wont work
Vacum turns on bag is empty nothing lodged in tubes powerhead light comes on but powerhead isnt working. Help
  • 1 more comment
  • Anonymous Nov 27, 2007
    light on power head does not work and belt does not move
  • Anonymous Mar 14, 2014
    powerhead only works intermittently starts and stops still has power
  • Anonymous Mar 29, 2014
    head works rod does not
Belt may be broken !
1)Snap off the cover over the light.
2) Undo the two screws that are on each side of the pipe.
3) Flip head upside down and use a flat screw driver to gently pry the side tabs apart.
4) Use another flay screw driver to pry the bottom from the top. Instructions are molded into the under side of the light cover.
5) Pry up the bearings supporting at each end of the brush and out it comes. Install in reverse order. Have fun!
Posted on Jan 11, 2008
Fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Posted on Oct 16, 2007
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Main powerhead useless
Make sure that the vacuum hole in the head unit, or the wand, or the hose is not blocked. You may also want to check the bag to make sure that the inlet hole is not blocked. The only reason for spitting things back out is that the suction is not working properly...
Nov 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Clogged
You can call your manufacturer of the vaccuum cleaner and get some help. Or try unplugging it and turn it upside down and beging taking it apart. Take the brush out and then work your way to the motor. There maybe something lodged up in by the brush. Also check in the bag department and look in the hole where the bag is installed. You may have some luck there. Good luck.
Sep 13, 2006 | Fantom Vacums FM760 Twister 500DX Bagless...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
308 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
