Question about EliteGroup ECS G733 Notebook
ANOTHER ECS G732 BOARD
PURCHASED TO REPLACE ANOTHER BOARD WILL NOT POWER UP NO LEDS NOTHING CHEAKED BOARD AND FOUND POWER AT SEVERL POINTS FROM THE BATTERY TO THE SWITCH CONNECTOR TRIED DIFFERENT SWITCH STILL NOTHING
  • keyboard cha Dec 30, 2008
    these site offer some ideas but did'nt help this board thks chuck
  • hungnv2007 May 03, 2009
    NO SOUND
No power and replaced the power board
What was the problem you ever faced, before replacing the power board? In the main board, there are test points, but normally no repair can be done with these board, other than replacement. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Sharp Aquos LC-60LE640U 60" Class LED...
Need install manual for gl8e motherboard plz
have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Aug 31, 2011 | Computers & Internet
I try to connect my ECS Motherboard one again but
you may have misplaced the power switch connections which come from front pane to the mother board
there are many of them like pwr switch, reset switch
hdd led etc
check *********** board it will be indicated where to connect the pwr switch pwr led etc
May 07, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Looking for conection points prescott mother board (533)
Follow this diagram:
Please rate me if i am helpful to you.
Thank you.
Sep 02, 2009 | PC Chips P21G (881038000916) Motherboard
I have a compaq 15" monitor which has no display.
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
Dec 19, 2008 | SAMTRON 55V 15" CRT Monitor
Acer CRT Monitor with tic tac sound
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
Oct 13, 2008 | Computers & Internet
Philips 105S51, 15 in. 15
1. cheak the Bridge diodes , power capacitor , PTC., FET ,3842
2.total power section cheaked it
3 AC fuse valu is 3Amp
HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
EliteGroup ECS G733 Notebook Logo
276 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
