Onkyo TX-DS656 Sub-out stopped working
Isolated to receiver as sub works fine on other system. Tried every possible switching configuration going back to User Guide. Attempted to drive sub from all connections in Multi-Channel Pod and no results. All other sound works fine. Thank you for your suggestions.
SOURCE: very low ouput from subwoofer preout
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
SOURCE: Onkyo 805 sub hook up problem
Looking at the back of the sr805, there is a second subwoofer output, this one is the preout. 4 rca jacks to the right of the non-preout subwooker. Moved it, and all works now.
Posted on May 15, 2008
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
renosean
  • 492 Answers
SOURCE: No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Posted on Jan 06, 2009
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
I have my Onkyo tx ds656 hooked up to my HDTV via the cable box. Everything works fine, except that there is a noticible delay in the syncronozation of the sound and the video. Is there any way to correct...
It's the nature of the beast. The TV has to process the digital video bitstream more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. I didn
Jan 24, 2011 | Onkyo TX-DS656 Receiver
I own a onkyo skw 980 subwoofer and it just quit. I have only had the system for a month or so. I was listening to music, not loud and the bass (sub) just stopped. No crack, pop, or blown speaker. The...
How are you sourcing the program material to the sub? This TX-V940 receiver doesn't have specific sub support.
=== Just the same...
You need to first determine which is at fault - the sub or the receiver.
Connect the Sub Input to Tape Rec on the receiver (but DO NOT select Tape) and see if the sub reacts to your playing FM, for instance. If it works you need to go back to the receiver and the unknown method you're feeding the sub.
You could also test the sub with a CD player output but use a recording that starts low because you won't have volume control.
Dec 24, 2010 | Onkyo TX-V940 Receiver
TX-DS656 - No display, still works.
Mine goes out sometimes, if I go to the reciever and hit the "Display" butoon, the display lights up dim, at same time, I hit the " Dimmer" botton on remote and display works for about 1-2 weeks. Don't know what is cuasing it, but that got the dispaly to work. Can deal with that I guess.
Sep 02, 2010 | Onkyo TX-DS656 Receiver
Will skw204 power sub work with my txsr605 onkyo
yes here is the manual for it.
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
now you will see this picture on page 5
768816d.jpg now where it says 6 this is your line input. Now you will plug in a subwoofer cable to this and on back of your receiver to the subwoofer output. and you now must enable the subwoofer option in the setup menu of receiver i think it would be under speaker configuration.
Mar 01, 2009 | Onkyo TX-SR605 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
76 people viewed this question
 Grubhead
Grubhead
