Question about Gateway GX7018E PC Desktop
I want to upgrade to a new video card
I am looking to upgrade to a new video card for my Gateway GX7018E PC Desktop - Is there any that do NOT work based on size of the video card
  • 238 Answers
You should see the type of graphics card slot first if your motherboard supports AGP or PCI Express slot and the memory limit your motherboard can hold for graphics card.
Posted on Dec 26, 2008
  • 38 Answers
You can put new Video card accordingly. Just buy an good Video card which have inbuilt memory and that support your operating system. There are loads of Video card available in the market.
Where can I purchase?
Hi, it looks that your motherboard uses SATA for your components. You should be able to buy any new SATA DVD-R at NewEgg, eBay or your place of choice.
Jun 28, 2014 | Gateway GX7018E PC Desktop
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
I have a Gateway zx4351. Can I upgrade to a dedicated video card from my GeForce 9200?
It is possible... Yes.
Is it worth it... Maybe the ram upgrade to 8GB is worth the money...
Also, some all in one computers are very hard to even figure out how to open. You better make sure you can do it before you try. You also might want to check if opening the case voids your warranty too.
Specs:
http://support.gateway.com/s/desktop/2010/gateway/zx/zx4351/ZX4351sp2.shtml
Jun 19, 2012 | Gateway 500XL PC Desktop
Attempted to install NVidia 9800t on my Gateway GX7018E. Could not get Windows 7 to recognize the video card plugged into the pci-e slot. Is there a way to force recognition? I have changed the BIOS info...
Do you have another monitor or TV with dvi/hdmi? Try to see if that works. And it seems like you changed the graphics output while in Windows. Try turning it off, swapping the cable and turn on again.
Dec 29, 2010 | Gateway GX7018E PC Desktop
Video card upgrade for Gateway GT4024
Try looking up for Updated drivers at Gateway for your Computer. Also find out what video it's using (ie. NVidia, Radeon, etc.) Many times the Video Card maker will have the latest updates for video cards before they get to the computer maker.
Jun 10, 2009 | Gateway GT4024 PC Desktop
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Computer won't turn on at all
I think ur power supply SMPS inside the systemneeds to be replaced...
Jan 03, 2009 | Gateway GX7018E PC Desktop
Gateway GX7018E / T6420 = swap video cards for a test?????
No you cant, the gateway GX7018E uses integrated graphics like the T6420. You will have to buy a cheap PCI or PCI-E graphics card to test it out.
Jan 02, 2009 | E-Machines T6420 PC Desktop
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
Video card upgrade
Relevant link
Yes it does have an AGP slot, which you can confirm easily by looking at the motherboard. The AGP slot would be found at the top of the available slots and is brownish in color and slight smaller than the several white PCI slots.
As for what card to put in, that depends on your budget and needs.
If you're a gamer, spend as much as you can and go with a N-Vidia based AGP card.
Please rate this as solved once you've read it, unless you have further questions, then post another comment.
Thanks!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 17, 2007 | Gateway 310S (2900621) PC Desktop
Gateway GX7018E PC Desktop Logo
240 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
