Question about Video Game Consoles & Games
Connecting nintendo wii with bose 321 and tivo system
Just got a wii and unable to connect to my bose 321 and tivo system andrun through my panasonic plasma tv. Have tried several options,but can't seem to get it to work.
SOURCE: Bose lifestyle 25 system and Panasonic Plasma Tv not working together
I posted the message as Tet Tet before. I can now tell you that I have resolved the problem. The issue is with the Panasonic 50Inch TV. Some people reported the same problem but only when the TV was up on the wall. It turns out that the problem lies with the metal discs which screw on at the back of the TV to enable you to hand the TV on the wall bracket. In my case I had excessive interference caused at the back of the TV (could be the fan). When I put the TV on the wall bracket the metal discs would be in contact with the wall bracket which in turn was acting as an antenna causing the iterference to the bose remote which operates at a frequency of 27.45MHz. You can solve the issue by adding some insulating tape around all the metal discs avoiding them to make contact with the wall bracket. If that fails Panasonic will swap your TV for another one like they did with me. I can now enjoy my Bose System with the 50 inch Panasonic TV. It took me three months but managed to get a solution. I hope this helps. For further info you can mail me at rizzocarlo@hotmail.com. These discs should be made of metal because they are perforating the metal screen at the back of the TV. Panasonic please change this design.
Posted on Jan 16, 2008
SOURCE: Bose 3-2-1 connection
Connect the 360 and wii to the tv. Then connect the tv to the 321 using analog coaxials (red/white) or digital optical through the tv's audio out ports in the back. Then set the 321 to TV and you should be all set. Sound may not be quite as dynamic as if you went straight from the gaming systems to the 321, but should still work well.
Posted on Jan 30, 2009
RescueTechLA
  • 2653 Answers
SOURCE: How do you wire a Bose 321 to work with a
Are you planning on connecting it via RCA connections or Digital Audio?
Posted on Mar 02, 2009
SOURCE: Unable to locate opponents when connected
i phoned nintendo who told me that i need to increase the tcp timeout session by 2 or 3 times on my router as it is currently timing out before finding opponents. How I do this god only knows.
Posted on Mar 22, 2009
cjackHD
  • 71 Answers
SOURCE: how do i get my playstation 3 to connect to my bose 321 system?
Very simple. Red and White RCAs into any available input on the back of the 321. If the PS3 A/V cable can't separate the audio from the video (yellow RCA) by length of cable then get an RCA extension.
You can also connect this digitally with an optical cable (better sound) but you need to assign the optical cable to an input from your system menu. Your system menu can only be displayed on the TV from the video out of the 321. Go to "media center" and then down to "optical source"
Posted on May 31, 2009
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
I have a Bose 321 that I have connected to my TV and it works with no problem. I just bought a Panasonic Blu-Ray disc player and connected it to the TV using a HDMI cable. I then connected the Blu-Ray to...
hi,
u have to change the digital out setting of ur blueray player. change the audio output priority from HDMI to optical coaxial. surely u will get audio from bose.
ok
Dec 24, 2010 | Bose 3·2·1 Entertainment System...
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
I cant get my ps3 to come through my bose 123 system
More specifics would be helpful. To connect a PS3 to a 321 via optical, it depends on what series of 321 you have, but you need to assign the optical connection via the system menu. If this is the series 1 321, it's the settings menu. It can be assigned to any input "AUX etc.."
Dec 11, 2009 | Bose Audio Players & Recorders
How do i get my playstation 3 to connect to my bose 321 system?
May 30, 2009 | Sony PlayStation® 3 (60 GB) Console
Jan 14, 2009 | Audio Players & Recorders
321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Dec 30, 2008 | Bose (321GS) System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Video Game Consoles & Games Logo
309 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
