Question about Philips Senseo HD7820 Deluxe Single-Serve Gourmet Coffeemaker Black
My new senseo machines is not heating
The light on the front is flashing and i have "flushed" it around 30 times to see if i can get it to work but still no joy. i have followed the instructions to the letter and still it is not working. please can someone help me?
4 Suggested Answers
  • 17 Answers
SOURCE: Senseo won't fill itself on initial flush
Sounds like resevoir was not seated properly or something is in the resevoir. try pushing the pin on the bottom of the resevoir, do it over the sink, and see if water comes out. if tht works then its internal to the machine. Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
  • 6 Answers
SOURCE: Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: My senseo machine doesn't seem to produce the
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Posted on Apr 07, 2010
Senseo will not turn on or heat water
No need to see what is in the manual.
But what I type here, you also have to read.
The manual gives pictures. I'm not.
Remove the transparent back of the machine and fill it with water. a few centimetres under the top, you fine the line for max fill.
Then replace the transparent back on the machine. Then plug in the power cord and press the power on button. (once is enough) a light comes on and flashes, when the mains plug has power.
Then wait till the light stops flashing. In the mean time put a coffee pad in the top and close the top all as described in the manual.
Place one or two cups under the nozzles and press the button with the one or two cups. (two cups gives twice as much water, so place two cups.
That is all.
Jul 21, 2014 | Philips Senseo HD-7810 Coffee Maker
Descale light came on yesterday, have descaled as per the instructions but the descale light is still on
happened to me once this worked for me . had to fill tank 2 more times to allow the machine to flush the descaling mix (think its part of the cleaning process but the instructions are a little vauge)after this it worked fine
Apr 16, 2011 | Philips Senseo HD-7810 Coffee Maker
The machine locks up and then when it heats up the water does not flow from the spout
Not sure what you mean by 'locks up', but if the slow flash changes into a steady light in the power button, 2 situations can occur in your case:
  • when nothing happens at all when you press one of the buttons: the button or the PCB inside the Senseo have failed.
  • when the power light starts slow flashing again: the pump motor has most likely died.
Either case requires contact with a repair shop . .
Oct 28, 2009 | Philips Senseo HD-7810 Coffee Maker
Aug 26, 2009 | Philips Senseo HD7832 Coffee Maker
Not heating up still cold
I had the same problem after only a few months. There is a float at the side of the water resivour, this float also has a magnet attached to it and for some reason becomes lodged at the bottom of the tank, telling the machine that there is not enough water in the tank, even when there is. Use a magnet on the outside of the resviour, connect it to the one on the inside and lift very slowly upwards...Hey presto the light stops flashing and the water boils
Aug 03, 2009 | Philips Senseo HD-7810 Coffee Maker
The water is not heating up!
Makesure the water holder is seated right. also follow the directions toclean it out once.
If no good,
Feb 01, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Oct 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo 7818
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
Jan 13, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo making to much coffee
Try flushing the machine by filling the water tank with water and then pressing both the one cup and the two cup buttons at the same time (make sure to put a big enough bowl under the spout). If this doesn't work, give Senseo a call: 1-866-4SENSEO. They should be able to help! Good luck!
Aug 15, 2007 | Philips HD-7810 Espresso Machine
Philips Senseo HD7820 Deluxe Single-Serve Gourmet Coffeemaker Black Logo
73 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
