Question about Kenmore 24032\24036 Top Load Washer
Kenmore Washer won't drain or spin.
Washer will fill up and wash but it won't drain or spin in any of the three cycles where it says rinse and spin on the timer. I have moved the knob to different locations with no luck. Could it be the timer or vacuum break or something else?
Thanks!!
  • 640 Answers
Check lid switch
Posted on Dec 28, 2008
My Kenmore compact washer with dryer on top, will not go from the first wash-rinse-drain-spin cycle to the second rinse-drain-spin-off cycle.
Check and make sure the door is pushed all the way down until you hear a click. If it starts with the next cycle, then your door switch may be bad. It's a pretty easy fix, but I would watch a video at least before doing it yourself.
Oct 09, 2016 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
