Question about Acer Aspire 3050-1733 Notebook
Acer 3050 Hello there, I read your post about the keyboard and the mouse nit working with the battery in. I have the same problem and i was wondering if you solved you problem so you can help me tacle mine Thanks Kevin
  • 1 more comment
  • Anonymous Dec 29, 2008
    no, I have never been able to solve the issue
  • wallenalle Jan 09, 2009
    I have the same problem. I couldnĀ“t figure out what the problem was, but when I read your note here I discovered that my problem was exactly the same. When the battery is away It works perfectly.
    Have you bought a new battery, and did work then...?
  • bradybunch1 Jan 17, 2009
    i had the same problem i fixed it buy takeing out the battery and running on mains power , i also had to go into device manager.you will find this option in control panel then click on batteries a drop down menu will show up click on microsoft acpi battery control and disable device .worked for me but now i am not running a battery
Why are the batery powerlight not shining green on microsoft wireless keyboard 3050. Don't find a on off button.
I don't think there is a power button on the keyboard. It is probably due to the batteries being dead or very low. Change them and you should be fine.
Oct 16, 2016 | Microsoft Wireless Desktop 3050 Keyboard...
Laptop does not turn off - only reboots. Mouse and keyboard is slow or will not respond - usb keyboard and mouse work ok. Can not make "factory disk" and any upgrade to OS fails.
Your computer needs to be diagnostically tested by a certified technician. They have an excellent repair program at the Staples stores now. Check it out. Joe
Mar 13, 2010 | Acer Aspire 3050-1733 Notebook
My Key board dosnt work on my acer aspire 3050 but
Log into safe mode and then try a system restore
Click on start and then all programs
Click on accessories and then system tools
Choose system restore on the list and restore to an earlier time
Then choose a date at least a day before this first happened
Please let me know the results
Dec 29, 2009 | Acer Aspire 3600, 5030, 5500 Keyboard...
Slow Keyboard and mouse, DPC's problems
switch everything over to usb...mouse and keyboard... or by a ps2 to usb adapter and test it out... one usb to ps2 adapter can handle both keyboard and mouse... if that doesn't work its either a virus or memory...
Dec 22, 2009 | Acer Aspire 3050-1733 Notebook
Wireless mouse works not keyboard
check the batteries in the keyboard, if they are working then goto control pannel and goto install new hardware and try installing your keyboard driver from there. if it is nit getting detected then goto device manager and try to check from ther if you can detect your keyboard from ther.
Aug 08, 2009 | Computers & Internet
Acer 3050 battery doesn't charge and causes CPU to run at 90%
I contacted Acer about the problem and their solution was to buy a new battery since the computer was not longer under warranty and they really didn't know what was going on! In talking with friends, and checking on-line, the consensus is that laptop batteries don't last more than two years. You can keep them charged, let them run down, recharge them frequently: they still will only last about two years.
I just find it hard to believe that Acer has never heard of this problem, especially when I'm reading similar posts on this site.
Anyway, as deviant00 suggested, I got a new battery on Amazon.com for $56. They offered $30 off if I signed up for their credit card. The final cost was $26. The battery came today and the computer works like a charm. I also followed jell587's advice and scanned the computer with the Malware he suggested:no viruses.
The solution for me was buy another battery; expect it to last for a couple of years.
Thanks for all the help.
Feb 19, 2009 | Acer Aspire 3050-1733 Notebook
Acer 3050 notebook.
sometimes corruption in windows can occur this kind of problems...but for now you can use a USB DRIVER LESS keyboard...to log in
Sep 06, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050 keyboard issues
go to my computer, right click, properties, device manager, look down list for keyboard, click '+' sign, you will see your keyboard listed, right click select uninstal, then restart notebook it will reinstall itself and should be working as normal.
Sep 03, 2008 | Acer Aspire 3050-1733 Notebook
Keyboard Malfunction
I suggest you to remove battery.
If this is still not working, your keyboard or motherboard is bad.
Did you spills any liquid on your keyboard ? if you did, probably only your keyboard.
From your explanation, i suspect it's motherboard.
Jul 21, 2008 | Acer Aspire 3050-1733 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3050-1733 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
