Question about Sharp 25H-M60 TV
Cant get local channels
I am using an outside antenna but for some reason this set wont pick up or cant tune in channels 40, 31 58, and 03. I have only had the set a few days could it be that it was programmed by a remote and these channels were not stored in it memory? If this is so, what can I do to fix it.
  • Denise Talmadge Apr 18, 2007
    I guess I should of mentioned that the only way visually to tune this set was with a remote. This set has no other way to get to it. On the front is the ON/OFF, CHANNEL UP/DOWN, and
    VOLUME UP/DOWN. On the back side there is only the antenna conncetor, vertical and horziontal and of course the power plug.
  • Anonymous Nov 19, 2007
    my tv want pick up chanels 2,3,4,5,6, and 14 help me please
    President:
  • 1,284 Answers
If you can manually tune to the channels with no problem, then I would go in and add then into memory manually. If not then exchange the set as it might have a bad tuner or an AGC (automatic gain control) issue.
Posted on Apr 18, 2007
Getting "tuning error" messages on certain channels on new Samsung uhd 4k 6840 TV. How do I clear this?
if using an hdtv antenna,it means that it has moved and cant pick up channel anymore,rescan for channels
May 30, 2015 | Samsung Televison & Video
Cant retune through dvd player
Sounds like a few things going on here... Your indoor antenna for one is probably not making it easy for you as an outdoor antenna will work a whole lot better. This is why it open picks up half the channels and they are pixelating. Also you may have faulty rf leads. Replace these.
Feb 25, 2014 | LG Televison & Video
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Tv wont work with antenna
There should be an antenna to receive local transmission signals.
Apr 01, 2013 | Emerson CR202EM9 TV
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
Tv will not recognise an antenna
Try to search for the channels using the antenna directly into the TV (remove the splitter) if you can pick up all the channels, then there is a problem with the splitter, if you still can't get anything, then most likely the tuner in the TV will be at fault.
Oct 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Cant get certain channels
you may need an outside antenna Digital tvs need a strong siganl easy fix just hard on the wallet
Jun 22, 2009 | Samsung HL-S5086W 50" HDTV
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
DH Channels
I cant get all my channels on my tv. I do my channel scan but all i get is 13 channels
Mar 20, 2008 | Hitachi 57F510 57" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
