Question about Whirlpool Calypso GVW9959K Top Load Washer
One of the electronic panels need to be replaced can I buy it ?
I need to replace one of the electronic panels Can I buy it and do it myself?
Yes call sears parts and give them serial# which is located under lid.depending on model,there are 2 screws at the bottom back of the contol panel.remove and lift panel.and you'll see the boards.
Posted on Dec 26, 2008
My casio px 130 power input is broken, so I took it apart. Now I'm simply looking to buy a replacement part (the power jack) and replace it myself.
recommend electronic component store. not sure which country you are from ?
in Australia Jaycar
You will need desolder braid
https://www.youtube.com/watch?v=htrcZuK_ZsY
https://www.adafruit.com/product/149
You will need solder
you will need a soldering iron
https://www.youtube.com/watch?v=oqV2xU1fee8
you need safety glasses
you need a steady hand
You can either remove the component first and take it to the electronic component store to find a replacement part
or take the piano to the store and open it up and show them the part you need to replace.
electrician will most likely not be the right person an electronic technician as the socket will be for a low DC voltage plug from an AC - DC adapter most likely.
Sep 13, 2016 | Casio Privia Px-130 Px130 88 Key Digital...
No picture on proscan 26LB30Qd LCD HDTV
Check Ebay for parts supply
Check Youtube about how to fit
Sep 06, 2014 | Televison & Video
The glass panel on my tablet t2010 is cracked - is it something I could replace myself - or is this only a job for a tech? where is it best to buy a replacement part?
You COULD replace it yourself, but i would highly recommend you get a tech to do it for you. The reason i say this is because electronics repair is a tricky business, fraught with dangers on the micro- and nanoscopic level. Unless you are handy with a screwdriver and own a ESD (electro-static discharge) bracelet, get a tech to do it. As for replacement parts? try ebay. thats where i get all of my stuff.
May 05, 2011 | Fujitsu LifeBook T2010 Tablet PC
We bought a used Gemstar Guide+ tv and were told that the cable plug did not work. After buying chords to bypass this and working with the Direct TV rep, it seems that the video is out on the TV. I hate...
No,this problems could be any things goes wrong in electronic components parts by in the tv main board or the CRT tube video board.Must have electronics experience to trouble shoot and repair to solved and replace electronic componnents parts.
Nov 17, 2010 | Televison & Video
Plastic piece on inside of where power plugs into back of computer broke how can i fix it myself
  1. Be highly skilled in electronics soldering.
  2. Buy a replacement power jack, Jacks for most models are available on EBay
  3. Using soldering iron, and other required tools, remove old jack, then clean the connections, and solder new jack in place.
For what it is worth, I opted to buy a replacement motherboard, (also available on EBay) and replaced it (About an hour job for anyone familiar with working on a portable system.) Generally, if you don't do electronics soldering it is not recommended for novices (I'm great fixing computers, but I **** at soldering)
Oct 14, 2009 | Sony Computers & Internet
I have a phillips 42'' lcd tv and was told that i need to replace my ssb board and it would cost 500 dollars. how can i fix this myself if i buy the part
ssb board should be available thru tristate module or pts electronics-if you give them the model number they can give you the price
Sep 04, 2009 | Televison & Video
Akai LCT2785TA Won't Turn On
It's worth a shot.First I would open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.Then you can get the stuff you need to replace the bad capacitors.This should get it working again.If it is anything else,you will have to buy some equipment like a multimeter to test the components,and find which ones are bad.As far as what you need,it all depends on how much you want to get into this,and,or other electronics.You would need a soldering iron,solder,solder braid,and a desoldering bulb/plunger to get started.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Oct 18, 2008 | Akai LCT2785TA 27 in. LCD Television
SB for KP-57WS500
You can buy replacement here:
Appliance parts, electronics parts & more from PartStore.com
Buy also the service manual, you find it on same website , the manual has diagrams that you must follow to test and replace the faulty part.
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
HP 2025 20.1" Monitor
Unfortunately, the LCD screen of any screen is always the most expensive part of the monitor, and it usually costs as much as the monitor itself to buy, not including shipping and replacing (unless you plan to replace it yourself). I could not find any replacement screens myself, and they are very hard to find. My suggestion is to just buy a new one. Sorry.
Feb 11, 2008 | HP 2025 20.1" Flat Panel LCD Monitor
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
