Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water running from under front grille of whirlpool side by side
Before I turned the water valve off, it ran contantly without shutting off. Now water is just running from under neath the front grille. Is it the water line or vaporator fan?
Fan Motor in Freezer has stopped working,
Posted on Dec 28, 2008
  • 700 Answers
It should be the water line,, Under there is a coupling and also the hoses that run to the water dispenser. Pop off the toe kick and have someone turn on water slowly while you look for thesource of theluek. Good Luck
Posted on Dec 26, 2008
F8E1 code on my whirlpool duet. The plumbers were working in the house and shut the water off to the machine, then my girlfriend ran a load without turning the water back on.
ROFLOL and how did that work out for her I've heard of dry cleaning but dry washing . quite possibly all that burnt out is the water inlet valve.
Aug 04, 2015 | Whirlpool Washing Machines
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
Water dont shut off
If you unplug washer and the water is still running you need a new fill valve.
Jun 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do i remove water filter under the side by side refrigerator
filter should be removede by turning filter counter clockwise,as if "unscrewing",so to speak.no need to shut off water or anything,just unscrew-tip:might be easier to remove by removing ref. grill. ref. grill removes easier by doing this w/ both doors open
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Apr 11, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Where is and how do I change the water filter. refrig ED2CHQ*k*O.
most refrigerators have the water valve in the rear of the unit which you can easily find. shut off the water supply line and unscrew the connection at the valve. it has a garden hose type connector. then with a small screw driver pop out the filter screen , run it under water until it's clean then re install it squarely in the valve reattach fill line and turn water back on. that's it
Jan 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
"pipe hammer" from water line to in door ice/water dispenser
try to turn down the valve that feeds your refrigerator water inlet to see if that can help. It's most likely that you have too much water pressure feeding the unit and the valve is having a hard time closing off the flow of water. Good luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool refrigerator side by side
hi. thanks for the question. To see if the problem is with the water valve, or ice maker. remove 1 wire from water valve ,at the back . now turn on the water . if water still flows. replace the water valve . if not replace the wire and try again .if flows replace ice maker. thanks the appliance doc
Sep 30, 2008 | Whirlpool ED2FHEXN Side by Side...
-whirlpool refrigerator water dispenser
this may still be under woranty check with sears / the padal makes contact with a micro swich and the switch enerjizes the water solinoid at the water line inlet . this solinoid may be sticking open as well. if you unplug the fridge and the water still runs its likely the water valve. if the water shuts off when you unplug the fridge it'll be the micro switch.. good luck
Jul 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
