Question about Sony DAV-HDX500 System
Dvd player won't open. Code 31
I loaded 2 dvd's into my new Sony DAV-HDX475 Home Theater System and it went into an error code C31 00. The DVD player will not open. I have tried re-booting and the display reads "Please Wait" and after a minute or two the error code is displayed.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    unplug system from ac outlet for couple of minutes then replug and power up. Hope dvd loading mechanism will reset and will play dvd.
welcomejee
  • 10594 Answers
SOURCE: You got the solution for DX150
Dear Nitingupta4u,
During display message "please wait" in DAV-DX150, there is problem have been observed in Optical Lens. If the Sled-Mechanism of Optical Lens doesn't work properly, this message "please wait" will be display. Your home theater has complicated disc loadimg mechanism and a skilled person can fix this problem. Please contact your nearest Sony service shop.
Posted on May 27, 2008
petraman7
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
SOURCE: SONY DAV-DZ720
you are stupid for asking me how i did it, did you give me solution, nonsense.
i hate you all.
Posted on Sep 05, 2008
SOURCE: I need device codes
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Posted on Nov 08, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
Type your question here...
I am having SONY DAV-DZ100 DVD Home theater system. The player is reading all the MP3 format cds and If I Insert any DVD, the message showing as "can't play this disc", even its a new DVD. Please suggest the solution.
Oct 12, 2011 | Sony DAV-DZ100 System
Sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Mar 02, 2009 | Sony DAV-FX10 System
Dvd's wont eject from my sony dav-fc7
because of bad loading mechanisum.
its belt melted i think.can you observe the motor runing sound the inside of player.
nuwan...
Nov 22, 2008 | Sony DAV-C770 System
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
SOnt DAV S550
There is a gear underneath the tray that may be broken or possibly the open close detect switch nay be bad. You will have to remove the tray,you will then see that gear.
Aug 10, 2008 | Sony DAV-C770 System
Got a code c-81 then dvd player won't do anything. Help
A bizarre coincidence but our Sony DVD player DAV C700 did exactly the same when the kids were watching a DVD. All other functions on the system are still working but the DVD player wll not eject or play - and the self diagnosis function C 81 remains illuminated on the display.
Aug 06, 2008 | Sony DAV-C900 System
Sony DAV SB100 home theatre DVD / CD problem
Grating adjustment is off, Compounded by dirt on the secondary lenses...accordianman
Feb 19, 2008 | Sony DAV-SB100 System
Error with DAV-S500
Sony DAV-S500 error c-81: On the rear side of the DVD board connected to the DVDv drive is a power transistor Q002 that is shorted BASIS-EMITTER. The device is an Toshiba 2SA1213Y (PNP transistor 1$) Replace and your DVD works! good luck :) Foxi from Budapest, Hungary, Europe
Jun 11, 2007 | Sony DAV-S500 System
Sony DAV-HDX500 System Logo
230 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
