Question about Averatec AV3220H1 (AV320H1-01) PC Notebook
White Screen I was at work with my laptop on a table and it was working fine, I went away for ten minutes and when I came back the screen showed only white. If I hook the laptop up to a monitor, I can see the normal screen. I am able to get into the BIOS by hooking it up to an exterior monitor, but the laptop monitor stays white. I have not as yet attempted a boot CD (cannot try book disk as no disk drive) but will be shortly. Does anyone have any suggestions or advice? I don't know how to take it apart to check the cables, so if this would be the suggestion please steer me to a url where I can follow someone's expert directions. I tried posting this on the Unofficial Averatec Forum but have not yet received a response. Thanks in advance for your help! :)
    President:
  • 2,961 Answers
It could be the graphics driver or the monitor. If you had a screen saver on or had the notebook set to hibernate, turn them all off first. If you are able to view via vga port then it could be a screen problem as the driver for graphics probably would give a problem on the vga also but it's worth trying firstly a system restore in case windows has updated the driver to a generic one, which can cause prioblems. What is unusual is you have to set your desktop on the notebook to allow an extended view to your external monitor or a dual view, but your allows it automatically, normally this would have to be done from your notebook desktop view. If no change try to uninstall the graphics adapter. Go to my computer, right click>properties>hardware tab>device manager and in the next window look down the hardware list to graphics adapter, click '+' sign and your adapter should be there, so right click and uninstall, restart pc and try again
Posted on Apr 18, 2007
  • andrew pester
    andrew pester Apr 18, 2007
    sorry, meant to say restart notebook and windows will find your graphics adapter again and install the driver and hopefully your screen will show.
SOURCE:
Zte source keep going black when charging
see solution, did you drop it or did it get wet?
Mar 14, 2014 | Cell Phones
Sony Bravia - no picture, no sound. Just a blank screen. We were watching a show and the screen went blank and no sound.
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Dec 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
Toshiba A105 S2719 screen problem
Is this behavior irrespective of power condition of the laptop, ie both ac and battery?
Please see bios bulletins for your system here. Sometimes a bios update can correct this kind of problem...
However, also note this article.
In the probable event that none of that works, it's probably your inverter or backlight (EL) panel, both of which can be replaced. The white lines are not a good sign. See other thread discussions of same here and here.
Google "diagnose laptop monitor failure" for more, or see this repair guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 19, 2009 | Toshiba Satellite A105-S2719 PC Notebook
Laptop monitor comes on bright whitish color
may be the LCD display of the laptopisgone or ur VGA adapter has some issues
Jul 26, 2009 | HP Compaq Presario C700T Notebook
Nothing appears on my monitor
Might be dead... try to leave it off for w while before trying again. check all connectors and if it still faisl to work your going to have to get a new one. Before that check your warranty and dealer and se if anything is coverd. best of luck
May 25, 2009 | Toshiba Satellite Pro 6100 Notebook
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Tutorial Screen
You can disable it under preferences
Dec 23, 2008 | Tomtom ONE 130 GPS Receiver
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
LG LS55 LAPTOP DISPLAY SCREEN BLANK/BLACK
I think your laptop might be stuck in SUSPEND mode. Try unplugging the power and removing the battery and waiting five minutes, and then plugging it back in. If this does not work, try holding down the power button for ten seconds at a time and rebooting.
Good Luck...
Nov 29, 2007 | LG LW20-EV Notebook
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Averatec AV3220H1 (AV320H1-01) PC Notebook Logo
80 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
